Sponsored by:
Sponsored by:
White Smoke
Old 07-26-2007, 01:23 PM
jerz2stl
Default White Smoke
I have a 91 Honda Accord LX that has 250K miles on it. As I accelerate I see white smoke from the exhaust, but none at normal speeds. The oil is not milky and the radiator fluid is not discolored or low. The car runs smooth no sputtering or missing at all. I replaced the plugs and changed the oil, I also added some "sea foam" to the engine oil and gas tank. Car ran even quieter but still see the white smoke every time I hit the gas hard and it disappears when normal driving. Is there any other thing I should look for i.e. change from regular unleaded to premium?
Thanks
Brett
Old 07-26-2007, 01:33 PM
smaglik's Avatar
Default RE: White Smoke
is it drinking oil at all?
Old 07-26-2007, 01:42 PM
jerz2stl
No it isn't....That's why I am confused....Not drinking oil, no anti-freeze oil mixture and no lose of power????? [&o]
Old 07-26-2007, 01:43 PM
finch13's Avatar
If you added Sea Foam you will get white smoke, although I'm not sure why it smoked before you added it. Also, I know Sea Foam is not recommended for high mileage engines as well (>100k I think).
Old 07-26-2007, 01:52 PM
jerz2stl
Cracked head and or gasket would produce the white smoke, also leave the milky oil and or low and dirty anti freeze. But would a burnt valve just produce the white smoke?
jerz2stl
Old 07-26-2007, 05:48 PM
finch13's Avatar
A burnt or bent valve?
Old 07-26-2007, 07:12 PM
jerz2stl
since I last check, you are correct it is now drinking oil.....No visable leakage
Old 07-26-2007, 07:40 PM
To verify internal engine problems, have a leak down test done. A compression test is easier to do, but might not narrow down the problem.
VI009DZ
01-17-2013 11:30 AM
Sunnysideup
03-29-2010 09:14 AM
Turbo_Accord_2010
02-02-2010 03:01 PM
sportsman1539
06-21-2006 07:19 PM
Sliom001
03-28-2006 06:57 PM
Quick Reply: White Smoke
