Sponsored by:
Sponsored by:
Trunk leaks Help please
Old 11-03-2009, 12:46 PM
DaIna-Kelela's Avatar
Default Trunk leaks Help please
Hey all we own a 1993 4-door Accord ES we got last March. I'm sure I'm not the only one with this problem. We didn't notice till the middle of the summer there is a leak into the trunk when it rains. I thought I sealed it around the channel that goes around the trunk, to include the antenna hole to.
Is there some place I'm missing?? Please let me know where to seal it up and possible areas where to look for other leaks. Thanks H-
Old 11-03-2009, 02:28 PM
kris_loehr's Avatar
When I worked at a body shop we would put someone in the trunk with a light and used a hose to find the leaks. It has been a long time but I think the tail light gaskets were a source of leaks in the older Honda’s.
Old 11-03-2009, 02:30 PM
Check the gaskets around the taillamp assemblies.
Got a sunroof? Check the drain hoses - maybe unplugged from where they go through the trunk floor.
If nothing else, climb into the trunk with a flashlight & have someone pour water all around with a garden hose.
hahah, kris beat me to it...
Old 11-03-2009, 04:42 PM
kris_loehr's Avatar
It has been close to twenty years and I can’t believe I still remember all this stuff.
Old 11-03-2009, 06:56 PM
Thanks guys, the tail light were where I thought the water was coming in I did do a caulking but I'm going to pull the tail lights off and re-caulk them with a better gasket caulk I didn't know about the moon roof tube I'll check it out. The water does seem to be accumulating in what looks to be the back half of the rear subframe where the trunk is welded to. I'll do the climb in the trunk thing soon first.
Thanks guys, H-
Old 11-03-2009, 06:59 PM
kris_loehr's Avatar
I am glad you found the leak. Most of the ones I saw at the dealer way back when were from improper collisions repairs.
Old 11-03-2009, 07:57 PM
deserthonda's Avatar
http://www.hondaaccordforum.com/foru...ead.php?t=3087
let your mouse do some clicking .and look in the DIY section first whenever you have questions
thaison86
06-28-2012 12:03 AM
JetJock
12-07-2008 04:10 AM
MNHONDAGUY
05-08-2007 07:52 PM
Green_Accord
04-25-2007 10:39 PM
longneck8769
03-28-2006 06:19 PM
Quick Reply: Trunk leaks Help please
