89 lxi oil leaks
Old Mar 26, 2006 | 01:48 AM
longneck8769's Avatar
Default 89 lxi oil leaks
i need help figuring out why my oil is leaking so bad. ive changed the valve cover gasket the oil filter and the oilpan plug any suggestions
Old Mar 26, 2006 | 01:52 AM
Default RE: 89 lxi oil leaks
possiable valve stem seals????
Old Mar 26, 2006 | 01:59 AM
how hard is that to fix? could it be the oil pan seal and also i need a new power steering hose any suggestions on where to get it or how to change it out 89 accord lxi FI
Old Mar 26, 2006 | 04:48 PM
lightshow's Avatar
yea that high pressure hose just get a new one. one bolt holds it to the pump and one nut holds it to the rack. in thoery its really simple but just make sure to wear some mechanix gloves or you will be giving some blood. also get a 30 back of beer cause it will help when you get frustrated. dont be afraid to unhook that sway bar a little.
Old Mar 26, 2006 | 10:56 PM
thanks alot i knew how to take it off on top but not under the car
Old Mar 26, 2006 | 11:05 PM
mbo1985's Avatar
I had a slow engine oil leak from my accord and It seemed like it was coming from the valve cover. It actually was coming from the distributor, so I just replaced the o-ring and that fixed my oil leak. It's worth a check.
Old Mar 28, 2006 | 06:19 PM
okay ill look into that
ccookie66
Apr 12, 2019 04:43 PM
Gordon
Nov 24, 2010 03:03 AM
Jay 3rd
Dec 29, 2008 11:39 AM
RA1525
Mar 11, 2008 07:02 PM
longneck8769
Mar 28, 2006 06:19 PM
