[DIY] License Bulbs
Old Apr 3, 2007 | 04:27 PM
cheeno
Default [DIY] License Bulbs
anyone have a [DIY] guide to switching the license bulbs out for an 05 accord coupe?
Old Apr 16, 2007 | 09:01 PM
GreekFreak
Default RE: [DIY] License Bulbs
Hey I am a rookie modifier here and I was searching this whole place for an explanation on how this is done... I found nothing so i literally just went outside and did it.
i have an 04 and im pretty sure it will be the same setup.
I first thought you have to take out the plastic covers above the license plate, but thats not really the case.
1. You'll need a flat-head screw driver or 2. (i used 2 to help me better)
2. Open your trunk and unscrew the plastic screws on the inner-lining of the trunk (you dont have to pull the lining off, but instead just get enough off to get expose the lights..you'll see the wiring harness.. ***it may take a little force to get the lining over the hinge that catches the trunk)
3. The LED harness is attatched to the plastic covers on the outer-part of the trunk. I found the best way to do this was to pop out the covers (they dont come out, but just give you enough room to pop out the two clips holding the LED to the plastic cover)
4. Once the hinges are clear of the plastic cover, you can get the LED part to come down so you can change the bulb...
5. reverse all the steps and enjoy your new lights.
I'm used a 194 bulb but i'd like something brighter. Let me know if theres any problems since its my first instructional post ever.
trijoon
Nov 20, 2010 11:34 AM
jbrams
May 11, 2010 10:30 AM
markus9175
Mar 27, 2009 10:35 PM
dengar169
Jan 9, 2008 02:48 PM
mlaccord
Apr 7, 2005 02:59 PM
