Adding the Homelink overhead console - Direct Bolt In?
Old Nov 27, 2012 | 06:37 PM
Mopar McNeer's Avatar
Default Adding the Homelink overhead console - Direct Bolt In?
I'm getting ready to add a ceiling console (sunglass holder/dome light) assembly that also has the homelink module built into it. My current set up does not have the homelink in it. I just wanted to double check and see if it was basically a plug-in-play drop in or if there is any additional plugs/wiring that needs to hooked up/run/installed.
Thanks in advance for your input.
Car info is in my sig, but it is in a 02 Accord SE.
Old Nov 29, 2012 | 10:53 PM
Anyone?
Old Nov 29, 2012 | 11:05 PM
Looks like we don't have anyone on at this time who has an answer for your question..
Old Nov 30, 2012 | 12:03 AM
Although there are different Honda part numbers for that unit, since you have the SE trim level, it should be plug and play. The SE has the moonroof, so there is more room above the headliner that can fit the various units; as compared to a LX trim level, which has no moonroof and has shallower roof.
msk
Sep 23, 2017 05:13 PM
james.roberts
Jul 23, 2014 03:05 PM
Smoky
Jul 24, 2011 06:47 AM
mysterysmoker
Aug 9, 2008 01:54 AM
dan_o_89_rs
Apr 28, 2008 07:47 PM
