Adding Homelink to Accord EX-L
Old Oct 26, 2005 | 06:56 PM
msk
Default Adding Homelink to Accord EX-L
New guy to the board, but long time Honda owner. My wife's new Accord EX-L 4 cyl did not come with Homelink. Other Accords do have it I've been told. Can I relace the sunglass holder/spotlight assembly with one that has Homelink from a different Accord model????
Old Oct 28, 2005 | 03:42 PM
Patrick's Avatar
Default RE: Adding Homelink to Accord EX-L
what is homelink?
Old Feb 1, 2008 | 04:15 PM
beige accord
ORIGINAL: msk
I am digging into this question myself. I can say on a newer toyota 4runner you can do exactly what you descibed ( I did for $76). I will go to a parts dept and see if I can resolve this. It really should work as why build different frames, electrical connections and headliner openings?
Old Feb 1, 2008 | 05:11 PM
HondatechAV6's Avatar
homelink is a programmable interface that you can use to open your garage door among other things as you get home.
the problem is there may not be a connector up there to plug it into on non homelink accords. i'll check into the etm later if someone else hasn't checked.
Old Feb 2, 2008 | 03:20 PM
beige accord
The homelink module 36650-TA0-A01ZB (ivory) A =gray, appears to be a direct snap in to the existing console. Problem is the part is 158. The console itself is 37. To the previous post, I am not sure if it is plug and play. According to the dealer the wiring harness in the sun glass holder areafor the ex-l 4 cyl is a different part number than for the 6 cyl ex l. However the drawing looks the same. So I cannot say it will electrically plug in. If I can get it discounted somewhere I will try it. The dealer did say I could buy it and return if in fact it did not work.
Old Feb 2, 2008 | 08:52 PM
yeah, there is no connector to plug it in.
however, you can just power and ground to it easy enough, i can help you with it, tell you where to route the power wire, etc if you're up to it.
Old Feb 3, 2008 | 10:00 AM
beige accord
Ok, I will take you up on that assuming I can get the homelink module under 100. Thanx
Old Feb 4, 2008 | 09:21 AM
catbert430's Avatar
College Hills Honda in Ohio is selling a homelink unit from the EX-L V6 that they've modded to run on battery power.
They probably would sell an unmodded unit as well that you could find a power supply for. I imagine other dealers could do the same.
Here's the link: http://www.collegehillshonda.com/hon...d_interior.htm
Old Feb 4, 2008 | 06:33 PM
that is awesome! but i'd still like to save batteries and run power and ground wires myself. [8D]
Old Mar 31, 2008 | 07:41 AM
buckeyeboy's Avatar
Adding Homelink module to 2003 Accord EX. Didn't like the look or fussing with my oldclunky garage door opener. Found a homelink module (actually out of Acura TSX) on Ebay, and traded units. Works like a charm!
Somevery clear instructions outlined on YouTube from College HillsHonda on how to do it.
