Broken Sunroof
Old Apr 12, 2008 | 05:35 AM
confuseid's Avatar
Default Broken Sunroof
I drive a 2000 Honda Accord Ex Sedan.
My sunroof cracks open in the rear if I press the middle button on the driver's side dash...
However, when I try to open it fully, it sticks. I think it may be jammed?
As warmer weather is coming along, I'd like to open the sunroof.
Anyone know how I can fix it? It seems nearly impossible as I can't even get it open so how can I possibly unjam it?
Old Apr 12, 2008 | 10:27 AM
sir_nasty's Avatar
Default RE: Broken Sunroof
Gently push up on it in the back as you operate the button and see if it will go any further, if it does then lube everything when it's up, if not It may be in need of some different repairs or adjustments and I'm not a good help there...
Old Apr 16, 2008 | 10:26 AM
confuseid's Avatar
I tried that, but that wouldn't work.
It might be jammed on the sides but there's no possible way for me to check it, because it won't open!
Is there a way you can open the sunroof manually? Or Do I have to take it to the Honda Dealership (cost me a fortune)!?
Old Apr 16, 2008 | 11:05 AM
finch13's Avatar
I've never had a sunroof, but I do know there is a way to open it manually. There is either a plastic screw you remove with a coin or its under the dome or map lights. Use an allen wrench or the supplied wrench to manually turn the sunroof open.
jam
Oct 24, 2013 08:11 PM
bcass689
Feb 8, 2008 01:05 AM
HondagalGA
Sep 13, 2006 09:34 PM
xxxcoojaxxx
Jun 30, 2006 12:02 AM
jayem722
Nov 18, 2005 07:06 PM
