can you repair halo's
Old Aug 8, 2007 | 09:12 PM
noboundaries6289's Avatar
Default can you repair halo's
hey all, Just got some new headlights and one of the halo's is already out. My original plan was to buy a new set and get a refund on these, but to save me a hassle, is there any way to repair burnt out halo rings in headlamps? thanks in advance
Old Aug 8, 2007 | 10:52 PM
HuYnHness's Avatar
Default RE: can you repair halo's
yeah i hear alotta people just change out the leds because they burn out quickly but a new one should last.
Old Aug 8, 2007 | 11:08 PM
Call or write to the company you bought them from..maybe they have somkind of warranty on them:
Old Aug 8, 2007 | 11:37 PM
i got them from nopi, they said the fastest way would be for me to buy a new pair at 20$ off to pay for shipping. Then send them the defective ones back for a full refund. It's annoying because it'll probably take 2-3 weeks to replace. ANZO has no direct warranty but said to go through retailer.
Old Aug 9, 2007 | 10:41 AM
t00fatt's Avatar
You can defiantly change them. There should be some extra wires you had to connect to power for the halos. Trace the wires and see where they go. Once you find the LED or bulb, its prolly a bulb if it burnt out already, see how you can remove it. Once you have it out u can change it to what ever color LED you want. I would get a bulk order of LEDs of ebay so you can fix your halo lights and change some other lights.
Old Aug 9, 2007 | 01:34 PM
ill try that next time i have them off. the wires come from underneath the housing.
Old Aug 9, 2007 | 01:35 PM
also just put sylvania silverstars in my high beams and adjusted all my lights. Good thing they're high quality ones. They have four adjustment screws for each side. 2 for high and 2 for low. The sylvanias are awesome compared to stock. I just hope I adjusted them good enough to not blind drivers.
Old Aug 11, 2007 | 01:21 AM
19Accord97
I bought 2 pairs of projectors, one needs to go back and the seller is trying to screw me over
But anyways, I am installing my projectors 2morrow and will be replacing the leds before I put them in with 13k mcd ones so the rings will be really bright!
As for the replacement...I think its going to be somewhat tough. The wiring is routed inside the housing, so I plan of drilling out a 1 inch hole in the bottome of the housing so I can access the leds with needle nose pliers. I just have to be careful not to drill in the actual visible part of the headlight. Its going to be a sucky job...but better than taking them out again.
How hard is the install? Can you give me any tips?
Old Aug 11, 2007 | 10:21 AM
y9pema's Avatar
you should open up the whole housing to get to the led's bake that sucker and pry it open. it's not that hard. doing a hid retrofit, and cant decide if i should put them in a pair of halos or into a black housing jdm's.
Old Aug 11, 2007 | 10:45 AM
19Accord97
I did that to my tail lights, but drilling two holes seem easier. I will let you all know how it goes. Doing em right now.
Jett05
Jun 4, 2012 12:48 PM
00AccordLX5spd
May 18, 2011 05:11 PM
pennsylvaniaron
Oct 24, 2009 12:20 AM
ourhonda
Dec 4, 2006 02:23 AM
subby
Oct 23, 2006 09:58 PM
