Front Door Panels- Need Help**
Old Dec 5, 2008 | 09:57 AM
kyler
Default Front Door Panels- Need Help**
I am trying to take off my front door panels on a 92. I've almost got it but i dont want to break the door handle coverand can't figure out how to get it off without doing so. im doing this in order to put in new speakers. thanks
Old Dec 5, 2008 | 10:00 AM
finch13's Avatar
Default RE: Front Door Panels- Need Help**
There should be a single screw that has a cover over it. Pop the cover and take the screw out. Then, the handle should slide to a side and come right out (there are ~3 hooks on the back of the handle). Next take a flat screwdriver or your finger and unsnap the plastic thing that holds the rod in the handle et voila, you should be home free!
Old Dec 5, 2008 | 10:01 AM
cjdm98's Avatar
Hope this helps.
Remove the mirror mount cover, power mirror, manual mirror. Take care not to scratch the door panel. [*]If applicable, remove the regulator handle (A) by pulling the clip (B) out with a wire hook (C). [/ol] [*]Remove the inner handle (A). Take care not to scratch the door panel.[*]Pry out the cap (B), and remove the screw.[*]Pull the inner handle forward and out half-way.[*]Disconnect the inner handle rod (C) and power door lock switch connector (D) (for some models). [/ul] [/ol] [*]Power window models: Remove the pull pocket panel (A). Take care not to scratch the door panel.[*]Pry out the cap (B), and remove the screw.[*]Release the hooks (C), disconnect the power window switch connector (D), and the power mirror switch connector (E), driver's side only. [/ul] [/ol] [*]Manual window model: Remove the pull pocket (A). Take care not to scratch the door panel.[*]Pry out the cap (B), and remove the screw.[*]Lift out the pull pocket. [/ul] [/ol]
Old Dec 5, 2008 | 10:04 AM
finch13's Avatar
Oh my, wow. You, sir, are amazing!
Old Dec 5, 2008 | 10:06 AM
cjdm98's Avatar
Sergay Brin and Larry page are to thank. lol
Old Dec 5, 2008 | 05:48 PM
kyler
Thanks guys
Old Apr 5, 2009 | 04:01 PM
Warrior Of God
Originally Posted by cjdm98
Hope this helps.
You are the man!!!!!!
Old Apr 5, 2009 | 08:10 PM
botang47's Avatar
he really is
Spoolme
Apr 9, 2019 04:44 PM
kyler
Dec 13, 2008 08:43 PM
custombass
Feb 28, 2007 01:59 AM
bnnj40
Nov 28, 2006 12:58 AM
fatalshock
Nov 2, 2005 08:18 PM
