headlight changing!!! i need help
Old Jan 14, 2007 | 04:46 AM
kevin_nguyen0862's Avatar
Default headlight changing!!! i need help
ok i know this is a stupid question but i need help. i just got some new headlights for my honda accord 2001 4/dr and i need to know how to change it or take the stock headlight out.. i tried earlier but i coulndt seem to fine the bottom bolts. do i need to jack the car up and go through the fender part and take the wheel off. please help. thanks
Old Jan 14, 2007 | 05:00 AM
02BlueAccord's Avatar
Default RE: headlight changing!!! i need help
u actually need to take off ur bumper. i tried to change mine to. so i called them and everyone said u need to take off the bumper. so i went to midas and they did it for like 75 bucks. u mite be able to find a differ way but thats the only way i know
Old Jan 14, 2007 | 05:05 AM
really???? damn that sucks. these anyone know of a easier way? but thanks 01blueaccord.
Old Jan 16, 2007 | 11:50 PM
hey but is taking the bumper off easy though i know it seems like a stupid question??
Old Jan 16, 2007 | 11:56 PM
blackex19's Avatar
this is very easy installation you shouldn't have to give away your money trust me i was in the same situation. All you need to do is remove some simple plastic screws at the bottom of the bumper and 2 screws that attach the bumper to the fender on each side. After that, all the bolts will be visible and should be fairly easy to remove. Youll be surprised how easy it is to remove the bumper, i was surprised myself.
Old Jan 17, 2007 | 12:14 AM
thanks blackex19. ill give it a try. did you have a 01 honda accord also?
Old Jan 17, 2007 | 12:27 AM
blackex19's Avatar
i have a 2002 but 98-02 should be the same, maybe a bit different but not completely. Good Luck!
Old Jan 20, 2007 | 04:32 PM
vtecdragon
Hey guys, i just installed these new halo projectors on my 2001 accord V6 and it is as easy at black said. Simply remove the two bolts that hold the bumper to the fender, remove the plastic screws that hold the bumper to the under carriage, then you find that their are about 4-5 bolts holding the headlight unit to the car. Easy installation, i did mines in under 2 hours. Hardest part of installation is putting the bumper back on properly.
Old Jan 20, 2007 | 07:37 PM
i know what your talking about vtecdragon i just did mines like 30 minutes ago. the bumper was easy to take off and the headlights alos but when it came time to put it back it was kinda hard. but i managed. the only problem now is that the head light has a little gap on the side at the fender which is fine becasue you cant really see it unless you really look at it. i will try and post up some pictures. thanks again for all your help guys..
Old Jan 29, 2007 | 01:05 AM
blackex19's Avatar
glad to hear you guys installed the headlights. .now lets see some pics!
AyashiFX55
Jun 4, 2007 08:38 AM
cellstop2
Jul 22, 2006 11:23 AM
Markus26
May 17, 2006 09:28 PM
05accord
Dec 2, 2005 09:22 AM
