headlight/corner light assembly
Old May 14, 2006 | 10:25 PM
96accord's Avatar
Default headlight/corner light assembly
Hello anybody/everybody...got a problem with my right front headlight. The headlight itself is fading to a yellow like appearance and I need to replace it. The corner light has a crack in it allowing water to get into the housing area causing the faded appearance. Another problem is that the weather stripping around the light is essentially gone. I was wondering if I should get a whole new headlight/cornerlight assembly or should I just replace the cornerlight and just clean the headlight since the main problem seems to be coming from the cornerlight. Also, I have looked at a manual and it doesn't say how to take out the whole headlight assembly...how do I do this and how hard is it. If anybody has any suggestions or tips, it would be greatly appreciated. Thanks
Old May 15, 2006 | 02:15 AM
mbo1985's Avatar
Default RE: headlight/corner light assembly
To reomve the headlights you will need to take off the corner light, the front grill and the bumper. Then there are five bolts that hold the headlight to the housing. It's a little bit of a project, but nothing too complicated.
Old May 15, 2006 | 11:41 PM
96accord's Avatar
Thanks for the help. I'll try a go at it and see how it goes. I may try just replacing the corner light first and possilby the whole assembly if that doesn't work. Thanks again.
simplistic808
Jan 8, 2009 10:44 AM
SL1K3
Mar 22, 2007 12:00 AM
96accord
Jun 18, 2006 05:23 PM
96accord
May 28, 2006 10:42 PM
96accord
May 15, 2006 11:35 PM
