help wiring halo tails
Old Feb 6, 2013 | 02:37 PM
93acc.ex's Avatar
Question help wiring halo tails
hey I recently got a 93 accord which im kinda ricing out just for fun. anyway I bought a set of halo tail lights. the reverse lights hook right up to original harness, but original brake bulb is deleted. but the problem is that the halo wires come out of the housing. 2 wires a red and a green. not exactly sure where to wire them too. then on outside lights the turn and brake lights hook right up but same thing, 2 extra wires from housing for the halo. any help on where or how to wire these is much appreciated. I don't want anything special just for the halo to come on when the lights are on. again thanks for your help.
Old Feb 6, 2013 | 02:39 PM
93acc.ex's Avatar
also I assume on the inside lights I can wire halos to original tail light bulb wires. but not sure which wire is + and -, any good wiring diagram links anybody? but on the outside lights im lost... lol.. again. thanks
Old Feb 18, 2013 | 11:09 PM
firefighter44's Avatar
Almost A Senior Member
the two wires (red and green) are supposed to be spliced into the positive and negative coming to the tail light via splice connectors. If your not sure which tail light wire is positive use a simple test light to see which has power and which doesnt when the lights are on, but remember you probably have 3 wires coming to your tail lights 1 for tail, 1 for brake and 1 ground, again use a test light to find which one is the tail light positive
kx250f519
Mar 13, 2013 06:07 PM
petef23a
Jan 3, 2010 10:47 AM
RuthlezzFL1P
Sep 10, 2008 02:59 PM
accord93
Apr 26, 2007 01:08 AM
GodMachine
Oct 15, 2006 03:40 AM
