Upgrading Stock Rims on 09 Accord Coupe
Old Nov 11, 2011 | 07:53 AM
satx981's Avatar
Exclamation Upgrading Stock Rims on 09 Accord Coupe
I have a 4 cylinder 09 Accord Coupe with the stock rims (seen below)...
I want to upgrade to the 18" ten spoke rims (seen below)...has anybody done this? How did it affect the vehicles performance?
Old Nov 11, 2011 | 05:33 PM
accordado's Avatar
I want to downgrade from 18 to 15 oem.
Old Nov 11, 2011 | 09:16 PM
satx981's Avatar
why is that?
Old Nov 14, 2011 | 05:44 AM
accordado's Avatar
ABS light goes on when breaking (sometimes) Honda dealer did an inspection and they suggest to use oem tires,they deleted the sensor code.Most of the rims i`ve seen for this car are 16" but stock is 15" ...i`ll trade my rims and tires for 15 in good conditions,i found a set of 4 rims for $ 299,00 at ebay.Take care.
Old Nov 14, 2011 | 08:22 AM
k24acura's Avatar
Have the brakes clean and adjusted. This could be an indication one is frozen or binding. The wheel should not play a part in lockup unless you have bad or bald tires.
[B]205[B]/55/15 If you wanted to upsize the wheel for every inch you go up in rim(15) you take off 10 from 55. This will keep the total tire height the same and not trigger abs or vsa lights.
Down size the rim is ok as long as the brakes will clear and the over all tire height is the same. Just note you will incur more body role in corners.
Old Nov 27, 2011 | 10:15 AM
Chaqui04's Avatar
So you want to go v6 18's OEM makes no difference fron what you have right now. Jjust do it will look alot better. "BUT" why not go with some after market wheels?
Old Nov 29, 2011 | 01:22 AM
satx981's Avatar
to me there's no better look than the v6 18" wheels
Old Dec 16, 2011 | 07:10 AM
accordado's Avatar
Thank you guys for the help so i bought a set of 15" steel wheels with tires and installed last weekend and the ABS light goes on after driving for few minutes.Next step is have the brakes inspected by myself and i`m thinking about to get Akebono pads,my concern is about safety and my car is all stock and want to keep the way it is...so dont call me grandpa...pls...the 18" rims is for sale or the tires separate and i`m trying to find out how to post pics here.
Zazoo718
Dec 1, 2012 07:45 AM
rykertest
Feb 23, 2010 12:07 PM
blazinbeetz
Jul 14, 2008 04:25 PM
r3nt
Nov 17, 2007 10:31 AM
thunder_x
Jun 3, 2006 06:27 PM
