03 accord stereo prob
Old Sep 25, 2007 | 02:27 PM
bigworm82
Default 03 accord stereo prob
i have a 03 accord and my stereo started to go dark where it would still work but no display so i went to check the fuse to see if it was blown and when i did that it stop workin completely but the fuse wasn't blown HELP
Old Sep 25, 2007 | 02:33 PM
sir_nasty's Avatar
Default RE: 03 accord stereo prob
sounds like the ever present backlight issue. Is the stereo still working you just can't see the display? If so do a search for 03 stereo and you'll see a TON of stuff
sir_nasty's Avatar
On a side note it's usually related to a burnt out bulb inside the radio, it can be replaced but I've never seen the instructions or walkthrough on how to do it....
Old Sep 25, 2007 | 02:36 PM
sir_nasty's Avatar
Here is the possible options for solution
http://www.carcomplaints.com/Honda/A...the_bulb.shtml
Old Sep 25, 2007 | 02:47 PM
bigworm82
it started out as the backlight of the stereo. But when i removed the fuse to check it and see if that was the issue i plugged the fuse back in and now the stereo doesn't work at all.. Should i remove the stereo or just leave it installed and figure something else out
Old Sep 25, 2007 | 09:48 PM
HuYnHness's Avatar
This is probably the recall problem that others have experienced. Call Honda and see if they can do anything.
Old Sep 26, 2007 | 12:15 PM
smaglik's Avatar
should be covered under good will...
shordinges
Jul 2, 2008 11:21 PM
eric07
Jan 6, 2008 07:50 PM
goodonmotors
Jan 1, 2008 07:04 AM
mlhand
May 3, 2007 12:57 AM
RebelK2
Jan 21, 2007 10:58 AM
