93 4dr accord window prob
Old Jan 6, 2008 | 06:32 PM
eric07
Default 93 4dr accord window prob
my driver side window slips out of place when i roll it all the way up and leaves a gap open and kind of overlaps on the outside is that a regulator problem or just some loose bolts somewhere any help appreciated thanks
Old Jan 6, 2008 | 07:37 PM
hondadude's Avatar
Default RE: 93 4dr accord window prob
get the door panel off, and look around.
from the description it sounds like the regulator is bad, or the run channel is out of the holders.
There is some adjustment to let it tilt foward and backward, as well as that you can move the bottom of the run channels in a little .
While it's all apart, lube the window run channels with silicone spray.
Old Jan 6, 2008 | 07:39 PM
eric123's Avatar
I would check t make sure the bolts aren't loose, on my 91 accord, I just got it and I rolled the window down and it slipped off the track and shattered the window. It was cuased because the bolts for the track were loose causing it to have pressure pushing it out of the track. I would check this first. It's very noticeable, just take off door panel and roll the window up and down u can see all the bolts that are loose.
Old Jan 6, 2008 | 07:50 PM
nafango2's Avatar
theres a TSB on this issue. the window track needs to be aligned.
Strack
Nov 2, 2008 10:02 PM
therivler1
Feb 12, 2008 08:10 AM
mlhand
May 3, 2007 12:57 AM
RebelK2
Jan 21, 2007 10:58 AM
