07 EXL V6 CD High Pitched Noise
Old Oct 3, 2007 | 08:52 PM
dmullen's Avatar
Default 07 EXL V6 CD High Pitched Noise
My CD Player (I have the in-dash 6 disc with XM Radio) makes a very high pitched tone when using the CD Player and the volume is loud (30+). It doesn't happen on FM or on XM. It's been that way since new and I'm going to take it in, but I'm just curious if this is normal.It's not your typicalbackround noise you hear in most stereos at high-levels - it's a much higher frequency than that.
Old Oct 9, 2007 | 02:20 PM
Thumper26's Avatar
Default RE: 07 EXL V6 CD High Pitched Noise
does it get higher and lower pitched as you speed up or slow down? if so, that's alternator whine. my friend's 98 accord does that too...
Old Oct 9, 2007 | 02:22 PM
falkore24's Avatar
big 3 upgrade then a ground loop isolator if needed ..... also, check that the grounds are solid from the radio.
Old Oct 9, 2007 | 03:10 PM
smaglik's Avatar
i dont hear it on mine...
pateati
Jan 10, 2011 03:04 PM
cmoorevt
Nov 12, 2009 06:36 AM
elbarto83
Oct 3, 2007 07:01 PM
asphyxxed
Jan 9, 2007 06:42 PM
FlyLow
May 15, 2006 08:57 PM
