09 Accord Want a system but want to keep factory radio
Old May 4, 2011 | 02:39 PM
  #71
frezel's Avatar
Pics of what ? Click on links to see specs of amps
Old May 4, 2011 | 06:28 PM
  #72
neophyte's Avatar
the jl is not fused according to the website and it does not come with one. i dont really like the idea of something not being fused. the ba comes with a 2 year warranty which is nice where as the kenwood has a one. as far as features they look about the same to me.
Old May 5, 2011 | 01:09 PM
  #73
keep_hope_alive's Avatar
The JL will be fused at the battery, no worries there. Back in the day, many amps were externally fused.
The Boston amp is the best bang for your buck.
Old May 5, 2011 | 08:42 PM
  #74
frezel's Avatar
i ended up with the boston acoustic amp bought it and its shipped, then i had a brain fart while driving realized it had high level inputs, BUT did not have a remote turn on feature. So i have to remove the dash now anyway, oh well. Thats what happens when you look at amps for weeks and change mind a million times. i read direction and they say run remote wire, so now i need a diagram of the factory 2009 accord wiring so i can tap a wire.
Old May 6, 2011 | 07:37 AM
  #75
pick up a Haynes manual for your car, it will have wire schematics and instructions for access. Mine is very helpful.
Chilton manuals aren't as helpful, IMO.
Old May 6, 2011 | 03:07 PM
  #76
frezel's Avatar
ok so i just got the wiring diagram for the radio here it is for a 2009 honda accord without nav
Audio
Audio
Item
Wire Color
Polarity
Wire Location
Radio 12V
white
radio, gray 24 pin plug, pin 24
Radio Ground
brown
radio, gray 24 pin plug, pin 12
Radio Ignition
purple
radio, gray 24 pin plug, pin 14
Radio Illumination
gray (parking lights), red (dimmer)
radio, gray 24 pin plug, pins 13 and 1 (1 CD disc player only)
Factory Amp Turn-on
white
radio, gray 24 pin plug, pin 17
Power Antenna
black
radio, gray 3 pin plug, pin 3
Left Front Speaker (+/-)
lt. green - pink or green - red
radio, gray 24 pin plug, pins 23 and 22
Right Front Speaker (+/-)
gray - red or green - red
radio, gray 24 pin plug, pins 19 and 18
Left Rear Speaker (+/-)
yellow - brown or green - red
radio, gray 24 pin plug, pins 11 and 10
Right Rear Speaker (+/-)
blue - orange or green - red
radio, gray 24 pin plug, pins 7 and 6
Center Channel (+/-)
[IMG]file:///C:/DOCUME%7E1/user/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image001.gif[/IMG]
Subwoofer (+/-)
green - red
radio, gray 8 pin plug, pins 8 and 6
Aux. Audio Input Left (+/-)
red - black
radio, gray 12 pin plug, pins 7 and 1
Aux. Audio Input Right (+/-)
white - black
radio, gray 12 pin plug, pins 8 and 1
RSE Video (+/-)
white - black (rearview camera video)
navi display unit, gry 28 pin plug, pins 13 and 12
RSE Audio Left (+/-)
black - red (XM audio)
radio, white 14 pin plug, pins 6 and 14
RSE Audio Right (+/-)
green - white (XM audio)
radio, white 14 pin plug, pins 5 and 13
Satellite Radio 12 Volts
white
XM Receiver, white 14 pin plug, pin 1
Satellite Radio Ground
black
XM Receiver, white 14 pin plug, pin 11
Satellite Radio Ignition
lt. blue
XM Receiver, white 14 pin plug, pin 2
Satellite Radio Antenna
(coaxial cable)
Satellite Audio Left (+/-)
black - red
XM Receiver, white 14 pin plug, pins 6 and 14
Satellite Audio Right (+/-)
green - white
XM Receiver, white 14 pin plug, pins 5 and 13
So do i tap or splice into the purple wire the radio ignition for my remote wire? also the remote wire what kind of wire do you recommend i have the power and ground wire bu no remote so i need to buy one, does it need to be fused?
Old May 6, 2011 | 06:32 PM
  #77
neophyte's Avatar
i wouldnt worry about fusing the wire. a piece of 16 or 18 guage wire should do you fine. and if you go that thick i think you run next to no risk or burning up the wire. and yes you would use the purple to run your remote.
Old May 7, 2011 | 06:53 AM
  #78
frezel's Avatar
So what type of wiring should i get? i have credit on amazon that i need to use do i get the :
1..D B LINK wire?
Amazon.com: DB Link PK4Z 4 Gauge Power Series Amplifier Installation Kit: Electronics
2.scoche revo pak?
Amazon.com: Scosche Revopak8 8-Gauge Revo Series Single Amp Power and Audio Kit (Silver/Black): Electronics
3..or something like monster cables
Amazon.com: Brand New Monster Cable MPC P300 Bap1000 1000 Watts 300 Series Dual 4/8 Gauge Amplifier Power Kit: Electronics
I will only be running the one 150rms sub and MAYBE a 2nd 150rms sub,so not sure as to what quality of wire to get.
Old May 7, 2011 | 11:10 PM
  #79
Don't tap the purple.
Factory Amp Turn-On wire, White. Use that for a remote! I never recommend using ignition wires for amp turn-on.
Always fuse the turn-on wire at the source! You are protecting the head unit, not the wire. 0.5A to 1A fuse.
No DB Link, wire is undersized. scosche or Monster is fine.
Old May 8, 2011 | 07:36 AM
  #80
neophyte's Avatar
how would it hurt the head unit if the wire is not fused? that wire is simply pulling power from the wire going to the head unit. it never goes into the head unit.
