1993 honda accord speakers
Old Nov 12, 2008 | 07:45 AM
paulhenrick2k8's Avatar
Default 1993 honda accord speakers
okay guys, i have honda accord lx year 1993.. i want to change speakers in front and rear..
what size should i buy for the front and what size will fit the rear? is it hard toinstall those speakers? what tools do i need? thanks!
Old Nov 12, 2008 | 07:54 AM
falkore24's Avatar
Default RE: 1993 honda accord speakers
Look at crutchfield.com and find the -outfit my car- link for speaker and headunit sizing info. No special tools & it's easy rfor me since I've done a few. If it's your first, you will probably break a couple of the clips on the door panel, but they're cheap, so no worries .... just get a pack before you start.
Old Nov 12, 2008 | 10:50 PM
thanks! but what clips? what do i need to do to remove the speakers first?
Old Nov 12, 2008 | 11:10 PM
cjdm98's Avatar
Clips that hold the door panel to the frame.. And in order to take the speakers off you need a Phillips and a flat head screw driver, Simple.
Old Nov 13, 2008 | 11:23 PM
where could i buy those clips? u mean, i still need to remove the door panel? like the whole thing?
Old Nov 14, 2008 | 11:06 AM
falkore24's Avatar
Yes, the whole thing. Get the clips at the dealership.
Old Nov 21, 2008 | 12:53 PM
by any chance, do u know a link where i could see how to install those clips? tnx
Old Nov 21, 2008 | 01:52 PM
falkore24's Avatar
They just slide into the holders on the inside of the door panel, then push into holes in the metal part of the door. They're nothing special .... also, if you are careful, you shouldn't be breaking many if any at all. I actually haven't used spares on any of my installs, but I've seen them broken and they are cheap to replace, so better off having a few handy since you haven't pulled a door panel before.
Old Nov 23, 2008 | 09:48 AM
benjiaccord's Avatar
Along with the pack of new clips, get a tool called a panel puller. It's a flat piece of steel with a notch cut out that grabs around the whole clip so you have a far less chance of breaking it.
Old Nov 25, 2008 | 02:52 AM
Antarctica's Avatar
Don't worry too much. Your speakers are so easy to replace. You just unplug 2 wires from the speaker, unbolt/unscrew it, clip the wires to the new speaker, and screw the new ones back in. The door panels are so easy to remove. That's the first thing I did to my car once (trying to change a speaker at that time).
BillieJackFu
Jun 30, 2011 05:52 PM
Legend
Oct 24, 2009 07:37 PM
geibn1
Jan 24, 2009 11:44 PM
LoD
Oct 14, 2007 11:58 AM
cellstop2
Jul 22, 2006 11:23 AM
