1993 Honda Accord LX Rear Deck Speakers
Old Jun 24, 2011 | 10:39 PM
BillieJackFu's Avatar
Default 1993 Honda Accord LX Rear Deck Speakers
I would really like a detailed explanation on how to remove the factory rear deck speakers. They are both dead. Tested the wires for power with some Kenwood 6.5's from my old car, wires are fine.
Hopefully I won't have to tear apart too much just to replace some speakers.
Let me know.
Thanks
Old Jun 24, 2011 | 10:58 PM
neophyte's Avatar
if it is anything like an 03.
1. go into trunk.
2. look around speaker. there will be plastic clips sticking trough the deck.
3. pop those up.
4. go in back seat.
5. remove cover
6. remove screws holding speakers in.
7. pull speakers out
8. (this step can be done from trunk or once you lift speakers) disconect wire harness.
9.
10. profit.
Old Jun 24, 2011 | 11:34 PM
keep_hope_alive's Avatar
i love steps 9. and 10. but i didn't see collect underwear...
i suspect a 93 is vastly different from even mine or newer. many times the factory speaker grill is secured from below - inside the trunk. in mine you have access to two screws per grill that come off, allowing access without removing the entire liner.
Old Jun 25, 2011 | 12:20 AM
I have been beating my head against the wall with this for the past day and a half. Then my dad says he thinks he has a Haynes manual for it. Sure enough 90-93 Accord manual.
So I'm going to give instructions, since other people might want to know.
1: Inside Trunk, 3 nuts, per speaker, undo the nuts.
2: Unplug factory harness.
3: Lift whole bucket from top.
4: Unscrew grill (4 screws) from bottom of bucket.
5: Unscrew speaker (3 screws) from top of bucket.
Reverse to reinstall.
My dad also said to use wire clips as to not cut the factory wire plug for use later or for resale. This is optional of course, you can cut the wires if you want.
Old Jun 27, 2011 | 10:00 AM
KnetW's Avatar
From: Cedar Rapids, IA (they made a movie about it)
Originally Posted by neophyte
9.
10. profit.
Hey!
That's 2/3 of my new business plan! That was supposed to be secret!
Old Jun 28, 2011 | 09:36 AM
Thanks for the info. You can get factory clip adapters so no wires are cut, but aftermarket speakers use .250 female disconnects and it is highly unlikely someone will reinstall a factory speaker in the future.
Old Jun 28, 2011 | 05:11 PM
neophyte's Avatar
Originally Posted by KnetW
Hey!
that is a 100% fool proof way to guarantee success.
Old Jun 29, 2011 | 03:24 AM
I just used some wire clips with a spade receptacle, some fancy clips my dad had in his garage.
Old Jun 30, 2011 | 05:52 PM
bigpat's Avatar
Almost A Senior Member
This is the exact sequence that I used to remove and replace my rear deck speakers last week on my 1993 Accord LX. Not too hard to do, just take your time and do it right. Be sure to check the polarity of the speaker wiring to get the most sound and best results. The original speakers had completely rotted away to almost nothing. Next will be replacement of the front speakers in the doors. That will be a drag since I will need to remove the door panels and safely unplug all power door lock and window switches...YIKES !! Re-assembly is always a nail biter....
paulhenrick2k8
Nov 25, 2008 02:52 AM
superballz00
Jul 26, 2007 05:56 PM
zubes
Oct 20, 2006 05:36 AM
ule
Oct 2, 2006 02:56 AM
MassAccord
May 6, 2006 10:41 AM
