1999 Accord Ex driver side speak problem
Old Feb 16, 2012 | 02:16 AM
HaPyro720's Avatar
Default 1999 Accord Ex driver side speak problem
I am having problems with the speakers on the drive side, both front and back. I switched the back speaker and they booth work. The audio system in the car is stock.
Old Feb 17, 2012 | 12:50 AM
keep_hope_alive's Avatar
Where are the balance and the fader adjustments set at?
Old Feb 18, 2012 | 10:23 AM
HaPyro720's Avatar
I tried setting those, it did nothing.
Old Feb 23, 2012 | 06:03 PM
did nothing? as in the adjustments made no difference regardless of where they were set? changing balance and fader should do something
did you buy the car recently? it is likely the previous owner hacked the wiring. you'll need to inspect to ensure no factory wiring is cut. same with the door - inspect the wiring/speaker.
i don't fully understand the problem. what do you mean by "switched the back speaker" - switched how/with what?
southbronxyank
Jul 26, 2014 10:49 AM
jza240sx
Apr 30, 2013 04:14 PM
YeuEmMaiMai
Oct 8, 2006 05:08 AM
marbro
Mar 31, 2006 02:41 PM
