2000 Accord Antenna Ponderings
Old Jan 30, 2008 | 05:55 PM
DenT
Default 2000 Accord Antenna Ponderings
I have a 2k accord and i put a 2nd new head unit in. I believe the antenna is that little nub hanging out of the headlineer in the back mounted to the window. I didnt bother to connect the blue (or blue/white stripe) wire(s) because i didnt have one of those mechanical antenna's. Doesn anyone know if the antenna is powered (like boosted) and needs to be connected? i know some are like in altimas and whatnot. My memory sucks and i cant tell if the reception is flakier when i'm in the mountains than what it used to be or not.
Old Jan 31, 2008 | 11:59 AM
00AccordLX5spd's Avatar
Registered User
Default RE: 2000 Accord Antenna Ponderings
The antenna winds around on your back glass via a small wire. It kind of blends in with the rear defroster.
Old Jan 31, 2008 | 12:35 PM
DenT
Gotcha... does it have power running to it or is it just passive? i didnt see power for it in any of the pinouts but i know that powered ones do exist.
Old Jan 31, 2008 | 03:37 PM
falkore24's Avatar
It's passive. The blue wire has nothing to do with it. If it were boosted, it would use an accessory power lead. The blue wire is only a remote and is not intended to power anything. It only provides an on-off signal. If you were to power anything with the blue remote wire, I'd expect damage to the head unit.
Reception can vary from one unit to another even though you are using the same antenna. If you want better reception, I'd recommend a satelite radio with a hard wired modulator ...... or even better, hooked to an auxiliary input.
Old Jan 31, 2008 | 06:08 PM
DenT
yeah i figured it to be a switching wire i just was wondering if it was powered if it needed to be switched on... well anyways you already covered that... thanks guys!
Transam4362
Oct 15, 2006 09:22 PM
Eauxkie
Sep 27, 2006 08:18 PM
aatc20
Sep 14, 2006 04:28 PM
msmiz
Dec 22, 2005 09:05 PM
pgopalak
Dec 17, 2004 03:30 PM
