2013 Accord EX-L Speaker Replacement
Old Dec 26, 2012 | 06:52 PM
kafn8d's Avatar
Default 2013 Accord EX-L Speaker Replacement
I'm considering replacing the OEM speakers in the kicks and the back shelf with Kicker 6.5-inch mid/30mm tweeter QS-series component systems (model 09QS652). These include the mid, the tweeter, and a crossover for each location. I'm keeping the OEM tweeters installed and setting up the Kickers as coaxial speakers.
I'm not changing the head unit or the amp; just the speakers. I'll replace the so-called sub with another speaker later, and most likely will not install a separate amp for the sub just to avoid the issues with the ANC system.
Question: Will the OEM head unit and amp have sufficient power to adequately drive the QS-series Kicker speakers? I listen to a variety of music at mid-volume.
Thanks!
Old Dec 27, 2012 | 05:40 PM
keep_hope_alive's Avatar
Adequately? no.
Minimally? yes.
factory amplification is minimal.
it'll get as loud as you may want, but distortion will be high. aftermarket speakers have much lower sensitivity.
but it depends on your expectations of quality. might as well try and if needed, add an external amp later.
Old Feb 28, 2013 | 07:55 AM
Spoolme's Avatar
anyone have a how to, to remove the subwoofer?
Old Jun 10, 2013 | 02:03 AM
aadragna's Avatar
Gotta remove the rear panel. Lower seat back and remove the push pins. Remove the side panels. (Disconnect the battery as the side curtain airbags are right there.) Gently push the Green pushpins up from the trunk area. Then lift the lid off. Speakers and sub are right there.
David Medina
Mar 6, 2014 07:47 PM
garyrocky1
Feb 15, 2014 10:11 PM
primetime
Feb 11, 2014 09:40 PM
pmay805
Sep 5, 2013 06:05 PM
fatboy
Dec 22, 2012 12:14 PM
