2013 coupe v6 ex-l - center screen rebooting while driving
Old Jun 13, 2018 | 07:08 AM
Spock69's Avatar
Default 2013 coupe v6 ex-l - center screen rebooting while driving
Hello. Searched for a Honda forum and found ya'll. Hope someone can help with a electronic issue. I have a 2013 accord coupe v6 ex-l w/ a automatic transmission and 33k of mileage. My issue is as follows. At times the screen in the center of the dash, (where the gas mileage info is displayed) will appear to shut down/turn off and the Hondalink logo pops back up. Almost like it's doing a reboot. The last few times it's done this I've been on the phone that is connected to the car and the call is not interrupted. The phone is a Samsung s9+. It happened a couple of times with my old phone a Samsung s7. I dont lose any info as far as phone settings and it doesn't seem to affect the mechanical operation of the vehicle while the reboot is happening. The random reboots are a bit annoying and worrisome. Any thoughts? Thanks.
Moderators of I have put this in the wrong category please move.
Old Jun 13, 2018 | 11:29 AM
Most of the time this IS the correct place for the question (general tech).
But I'm going to move it over to AV/electronics because the guys that hang out over there might be able to answer it better...
Old Jun 16, 2018 | 12:42 PM
keep_hope_alive's Avatar
Welcome!
That is unfortunate and the first time i've heard of this issue.
The screen is a monitor and is controlled by the head unit. I suspect this "reboot" is occurring within the head unit since the monitor doesn't have the ability to change what it displays.
Has the factory radio ever been removed? a stressed monitor connector could be a possible cause. You could replicate this by wiggling the connector behind the radio and seeing if it makes it occur.
I don't see how a BT connection would cause this and there isn't a correlation between a phone call and the screen output that I can think of (those are different circuits in the head unit). but if you're saying the "reboot" only occurs when on a BT phone call, then i would suggest the issue is internal to the radio.
Old Jun 26, 2018 | 10:23 AM
Spock69's Avatar
The radio hasn't been messed with since I got the car. The radio appears to be stock. The car was bought used and was listed as a lease vehicle in the report.
I was able to capture the rebooting on video and show it to the dealer. I got the "that's odd" response. I asked if there was an update for the system and there is. So its going to get its oil changed this weekend and the update installed. When I get it back I'll make a bunch of phone calls and see I'll let y'all know what happens.
Thanks
Old Aug 21, 2018 | 08:02 AM
Spock69's Avatar
Update, Well... dealer replaced head unit and radio. Started a phone call and it did a reset again. Called dealer so they could note my file and I'm back to trying to get a video of it doing the reset. Dealer suggested maybe interference from an outside signal. We will see. Just keeping ya'll updated.
Old Aug 23, 2018 | 09:33 PM
For the 2013 the bluetooth (hands free link) module is separate, not integrated like the 2014. I would suspect that separate bluetooth module is failing (it is located under the radio, mounted with the ANC module). confirm if they replaced that module as well.
Old Dec 1, 2021 | 07:58 AM
Csackey's Avatar
Angry
I am having this same issue on the 2013 Honda Accord. What i observed though was that it occurred when i receive a call or make a call to a particular number. I have not experienced it with any other number so i am left wondering what the issue could be.
Old Sep 25, 2022 | 05:33 PM
KobraX's Avatar
I have the same issue and it occurs if I open up my maps or trip computer or simply browsing through. I've replaced the DVD drive and it's been usable (the old drive was totally dead). I find it's worse when it's warmer. I have no issue with Bluetooth
Anyone know how I can diagnose this?
Old Sep 25, 2022 | 05:35 PM
KobraX's Avatar
Originally Posted by keep_hope_alive
Welcome!
Are you able to post a guide on how to do this? I'm having the issue but it's anywhere in the Navi computer.
Old Nov 9, 2022 | 10:59 AM
If there are issues that are temperature related, it's likely a problem on the circuit boards and not easily fixed or repaired.
Steamdonkey
Sep 10, 2017 03:36 PM
Bowen321
Aug 22, 2017 07:26 PM
duque6919
Oct 21, 2015 01:37 AM
SlowLogo
Aug 20, 2014 05:03 AM
