8" sub replacement mounting question
Old Jun 14, 2011 | 09:09 AM
KnetW's Avatar
From: Cedar Rapids, IA (they made a movie about it)
Default 8" sub replacement mounting question
For folks that have mounted an 8" sub to replace the factory 'sub', how did you go about that? I am wanting to put in a Polk MM840, and intend to build a sealed enclosure and mount it to the bottom of the rear deck. I was considering doing a free air (IB) sub but would still need a way to isolate the rear 6.5 speakers. Since there are 2 of those but only 1 sub, I figured the easier way tot go is to box in the sub. Its a 0.35 ft^3 volume box, seems like it should be easy. Am I missing something?
Old Jun 14, 2011 | 06:57 PM
keep_hope_alive's Avatar
you have to defeat the Active Noise Cancelling (ANC) feature (if applicable), you have to add an external amplifier - the stock amp can't power anything worthwhile, and you should consider decoupling the enclosure/sub from the rear deck if you don't want it to rattle like hell.
the amp you get should have auto turn-on and high level inputs. Kicker, Phoenix Gold, JL Audio all make amps like this.
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
hondaboostin
May 17, 2009 02:44 AM
