91 accord eld bypass......
Old Dec 14, 2013 | 07:07 PM
d-day's Avatar
Default 91 accord eld bypass......
Hi everybody, new to posting on the forum but have been a long time reader. I have found lots of good information on the site.
I am looking to bypass the eld in my 91 accord, I have read some threads about how to do it on a newer vehicle but not on a 91.. Well in case you couldn't tell my vehicle is a 91 Accord EX 5 speed, f22a4 with a6 cam. Nothing special just a little gas saver lol, anyway any help would be most certainly appreciated thank you guys
Old Dec 14, 2013 | 08:24 PM
The information is essentially at the first "sticky" at the top of this forum section. From reading that sticky thread.
Do at your risk!!!
1. Cut Green/Red wire from ELD to PCM.
2. The half of Green/Red wire coming from the PCM (ELD Unit Input) goes to the POLE of the toggle switch (12VDC SPST Toggle Switch).
3. The other half of the Green/Red wire from the ELD (Load Output) goes to THROW 1 of the switch; the POLE would be switched to this THROW to have ELD to work normally.
4. THROW 2 goes through an 820-ohm resistor to the black ELD ground wire at the plug; switching to this THROW would bypass the ELD and cause the alternator to turn on and charge the battery all the time. – Important: “Do not ground this resistor to chassis ground. “
Old Dec 14, 2013 | 08:28 PM
d-day's Avatar
Do at your risk!!!
I saw that sticky on the top of the page, I was just wondering if the wire coloring was the same has a newer vehicle.? Have that sticky printed out already. Its really good info
Old Dec 14, 2013 | 09:57 PM
The wire colors are the same for a 91.
Old Dec 14, 2013 | 10:58 PM
d-day's Avatar
Cool thank you
kevmoney265
Jan 5, 2023 11:16 AM
gillman331
Apr 4, 2013 10:38 PM
grimrepo
Sep 2, 2009 11:05 PM
WRX_ACCORD_136
May 30, 2008 12:51 AM
guardian10
Oct 20, 2006 09:40 PM
