wierd electrical problems 91 accord
Old Aug 31, 2009 | 11:55 AM
grimrepo
Default wierd electrical problems 91 accord
when my 91 accord is running. turn on the headlights or the vent the car guages go haywire. tach goes to 0, temp goes to red and then the car shuts off and sometimes wont restart. but if u turn headlights off everything goes back to normal. what is going on here?
Old Aug 31, 2009 | 01:07 PM
My guess would be a bad ground connection somewhere. That's usually the case for things that are SUPPOSED to be completely unrelated suddenly mystically affecting each other.
Old Sep 1, 2009 | 03:02 PM
grimrepo
thanks for the imformation it is greatly appreciated. could u maybe point me in a good place to start looking for this bad ground?
Old Sep 1, 2009 | 04:39 PM
I never owned a '91, so unless someone else chimes in, your best bet is get a repair manual. Look in the DIY section for a post about downloads.
Old Sep 1, 2009 | 06:07 PM
I think that there is a ground around the thermostat housing. The online manuals thread in the diy section has sites with a 91 shop manual. I think that autozone's site also has shop manuals that you can access.
Old Sep 2, 2009 | 11:05 PM
grimrepo
thanks for the info on the ground wires. the engine ground was loose. i also cleaned the thermostat housing ground. it runs good now. dont know which one, my guess is the engine. it didnt do that before i had tore apart to fix the head gasket. once again i appreciate all of your advice and info.
Hondalover
Mar 14, 2011 03:04 PM
ierider
Feb 21, 2011 03:08 PM
stevepasq
Sep 12, 2010 01:12 PM
sumpump_1203
Apr 23, 2009 12:38 PM
studentmechanic101
Apr 3, 2007 07:21 PM
