wierd power issue on 94 accord
Old Apr 21, 2009 | 10:16 AM
sumpump_1203's Avatar
Question wierd power issue on 94 accord
I have as 1994 Accord Ex and Im having issues with things not working. Fans, A/C, Interior light.... I have checked the fuses and nonw of them are getting any power, none. Its wierd though cause other things do work. Like my window, stereo, head lights front blinkers dont work but rear does.... Does anone have any idea what the issue could be? I checked the main ground and its good.
Old Apr 21, 2009 | 06:39 PM
hondadude's Avatar
underhood main fuses?
Old Apr 21, 2009 | 09:06 PM
This issue is going on with both sets, under the hood and inside the cab. Im not to sure what is the issue everything worked fine and then one day I hit a dear replace the radiator support and also added a visor light to the drivers side.
Old Apr 22, 2009 | 07:07 PM
hondadude's Avatar
Post
hit a deer huh?
So Nooooow we get the rest of the story........ [insert face palm here]
There is a power wire that comes from the battery positive terminal to feed the underhood fuse panel. Then the main fuses feed out to other circuits.
So if you want to follow the power trail I'd suggest you get the ETM for 94-95 accord.
It will have schematics in it and with a test light you'll be able to find out where you are losing the power
Old Apr 23, 2009 | 10:25 AM
Thanks alot. I really didnt think that hitting the dear would have made a difference that is why I didnt say anything. Like I had stated above Things work its just the fuse isnt getting or showing power. I really dont care but my girlfriend is pregnant and I dont have A/C and the fans arent blowing. So all that hot *** air is coming into the car and making her beach at me anywhere we go, lol.
Old Apr 23, 2009 | 10:26 AM
Its going to be alot of work but I guess Ill have to suck it up. Thanks again.
Old Apr 23, 2009 | 11:03 AM
Wow! Im done. Well not done yet but fount the issue is the power thing. See when I hit the dear I busted a cell in the battery and had to replace it well there was a little funk on the wire that I hadnt seen. Cleaned it up and there it goes. Still having issues with the fans not working though. Maybe i busted the motors up when I hit the dear. Well off to the junk yard.
Thanks for all the help.
If anything else come up Im sure the site will help.
Old Apr 23, 2009 | 11:16 AM
Aren't the fan relays or part of the wiring up front there between the grille & the AC condensor?
Old Apr 23, 2009 | 12:38 PM
I bleive that is where they are. When I had to replace the radiator I noticed that one of the wires was broken. I replaced the wire but dont think its stong enough. Is there a way to test relays? I have only a test light and Im not to sure how this is done.
Hondalover
Mar 14, 2011 03:04 PM
stevepasq
Sep 12, 2010 01:12 PM
guitarguychris
Jan 31, 2010 07:52 PM
grimrepo
Sep 2, 2009 11:05 PM
nafango2
Sep 29, 2007 04:02 AM
