'94 Accord's radio don't work, prev owner says antenna
Old Apr 3, 2013 | 03:35 PM
kevin6655's Avatar
Default '94 Accord's radio don't work, prev owner says antenna
Hi
Just bot a '94 Accord. Radio don't work, cd player does. The previous owner, a mechanic, whose daughter drove it, thinks it's the antenna. Any way to troubleshoot that?
Old Apr 3, 2013 | 08:05 PM
neophyte's Avatar
all static or nothing at all?
Old Apr 4, 2013 | 06:28 AM
kevin6655's Avatar
Hi
Thanks for the reply!
No static, nothing.
Old Apr 4, 2013 | 07:26 AM
keep_hope_alive's Avatar
remove it and check the antenna is still connected.
Old Apr 13, 2013 | 10:05 PM
Aaronl98's Avatar
I have the same problem with my 95, but I can't find the antenna any idea where it's at. I do get static though
Old Apr 14, 2013 | 11:19 AM
the antenna is connected at the back of the radio.
then it routes to an interface where it is imbedded in the rear glass. you'll see lines that are for defrost then separate lines in a different pattern that are the antenna. that connection at the glass can fail. inspect it.
you can buy a standard antenna and install through the trunk/rear quarter panel like most cars if you want. it can even be power. PartsExpress sells them.
mirandabell
Jul 10, 2012 08:50 AM
mustgetda360
Jun 20, 2011 07:46 PM
rcy
Apr 14, 2007 09:50 PM
Burnzy
Jul 17, 2006 01:20 PM
kturnerga
Jul 5, 2006 01:59 PM
