95 Accord ex sound comes from dash, but not driver door?
First time post, so here goes nothing. i have a 1995 accord ex 2.2 Vtec, and i hooked up an aftermarket deck and all aftermarket speakers. the door speaker on the driver side doesn't get nothing but static and faint music, and the driver dash also plays it very faint. is there any way to make the door speaker work better? and make both dash speakers play? any help appreciated.
EDIT: nevermind, problem solved. negative came disconnected.
I have the same thing mine is a loose RCA connection. I just wiggle it a bit and it works for x more days. Follow your left side connections. My loose connection is the iPod adapter so it only has the problem when using the iPod. If it's all the time the loose connection is between the headunit and the speaker. Good luck
jza240sx
Apr 30, 2013 04:14 PM
flash2067
Nov 27, 2010 12:51 PM
JD911
Oct 19, 2009 09:18 AM
