2000 Accord dash brake light comes on.
Old Sep 22, 2007 | 08:50 AM
gypsyman
Default 2000 Accord dash brake light comes on.
About every4 months, my dash brake light comes on and stays on. Brake fluid is good. Braking is good. E brake is fully released. IfI go under the hood and pop the cap on the master cylinder and put it back on, the light goes out and stays out till another 3 or 4 months go by. What could this be? Thanks for any help.
Old Sep 22, 2007 | 02:22 PM
deserthonda's Avatar
Default RE: 2000 Accord dash brake light comes on.
you need to replace the brake master cylinder reservoir cap,, it has a sensor in it and at time it fails ,it sticks , giving the impression that master is empty
Old Sep 22, 2007 | 03:20 PM
gypsyman
Thank you deserthonda. I appreciate folks like you who take the time to help us.
Old Sep 24, 2007 | 09:25 AM
00AccordLX5spd's Avatar
Registered User
I agree with dh. There is a float in the cap that goes up & down to measure the fluid. That float could be stuck or malfunctioning. You also may want to check the wire connections at the cap. There are two wires going into the cap that send the fluid level info back to the car's ECU. Make sure they are both connected and tight.
Old Sep 25, 2007 | 11:52 AM
tkundert2's Avatar
I believe there is a TSB on this. I replaced the cap and filter on mine and that fixed it.
Old Sep 25, 2007 | 12:26 PM
ORIGINAL: gypsyman
it is not just I that you need to tank,, But hundreds of HAF members that take time to help other members ,,
did the cap fix your issue ??
victorywhity
Mar 24, 2011 09:37 PM
David Crevenston
Sep 27, 2010 01:18 AM
David Crevenston
Sep 26, 2010 12:35 PM
herzy23
Sep 12, 2006 04:21 PM
