97 SE no lights on temp control guages
Old Nov 11, 2006 | 04:41 PM
accordfan222's Avatar
Default 97 SE no lights on temp control guages
I have 97 accord SE just bought few months ago. I have problem with no dimming lights on all the air flow buttons(buttons which direct the air flow in different direction i believe there is five or six all together) itself. The green light on top of the button is working fine. Plus don't have any light on fan control custer and no glowing light on heat control dial either. funny thing is there is light on the two buttons shows inside circulation flow and outside circulation flow. Anybody have idea if there is any kind of bulbs behind this buttons or there is a centralised one bulb gives a glow at night to all this buttons. I looked at the service manual for 94 accord and it shows how to take the console off but some how 97 accord do not have those screws which it shows for 94. Or if somebody have done this can you please saw some hints how to fix this. any input will be really helpful in fixing this
Thanks
Old Nov 11, 2006 | 05:29 PM
sir_nasty's Avatar
Default RE: 97 SE no lights on temp control guages
sounds like a burnt out bulb (or blown fuse.... but doubtfull it's a fuse) Here's some documents on removing that panel so you can inspect everythign
http://www.installdr.com/InstallDocs/Honda/Accord.html
Old Dec 8, 2006 | 03:03 PM
Thank you, This tooks me upto the bottom two screws of the panel. I found the info online for 94 accord. I think 94 to 97 accords are the same but somhow Manual shows 6 screws 2 at the instrument guage, 2 on bottom of temp control and one at the cruise switch and one at the rear defogger. My 97 does not have those two single screws at the switches. Is anybody out there know how to take the panels off to get to those bulbs I wrote in earlier post please. Thanks in advance....
ORIGINAL: sir_nasty
Old Dec 8, 2006 | 10:52 PM
ivrex's Avatar
yeah my 95 does the same thing, as well as the tranny lit up gears. all i got to do is smack it hard enough and it lights up, but wont stay on for very long. im almost pos its just a burnt out bulb back in there
this will give u access to those gauges
http://www.99accord.com/HowToGuides/...ntrolHowTo.asp
Old Dec 10, 2006 | 03:43 PM
ORIGINAL: ivrex
Thank you very much for the INFO.
njmodi
May 29, 2008 01:11 PM
Calidude87
May 22, 2008 03:27 PM
raf105
Sep 28, 2007 02:55 PM
PJ_STYLES_95AccordEx
Aug 21, 2006 11:45 PM
GLrunner13
Jul 22, 2006 04:28 PM
