Best Speakers w/ Easiest Install?
Old Sep 10, 2007 | 12:52 AM
  #21
HuYnHness's Avatar
Default RE: Best Speakers w/ Easiest Install?
similar to his approach but a alot cheaper and i bit more ghetto
buy some standard size male slide connects. you will have to cut it down a bit to fit in the stock connectors though. i used a dremel. works great if you dont want to mess with your factory wires.
Old Sep 10, 2007 | 08:46 AM
  #22
03Sleeper's Avatar
The front door speakers are kinda tricky to replace.
Old Sep 10, 2007 | 09:38 AM
  #23
jc07accord's Avatar
Thanks for the Info guys. I just order the kit for the rear. Does anyone know if the front speakers require the same kit? I was thinking about getting the Polk Audio DB5251 5.25.
Old Sep 10, 2007 | 07:34 PM
  #24
MacLeod's Avatar
Yeah, the front doors have those plugs as well.
Old Sep 11, 2007 | 12:22 AM
  #25
HuYnHness's Avatar
i guess im the only one around here who likes to riggerman
Old Sep 16, 2007 | 06:13 PM
  #26
jc07accord's Avatar
Mac,
Which polk audio model did you get in the front?
Old Sep 16, 2007 | 08:03 PM
  #27
MacLeod's Avatar
Their Signature Reference line. Im using the SR5250's 5.25" component set. ThatsPolk's "high end" line. Theyre based off their $2000+ LSi home speaker line. The only things I dont like about them is the tweeters are too big and it makes it hard to squeeze them into some places. Plus they dont give you a surface mount adapter so you have to cut a 2" hole in whatever youre going to mount them to.
http://www.polkaudio.com/caraudio/products/sr5250/
Old Sep 17, 2007 | 09:44 AM
  #28
falkore24's Avatar
Hey MacLeod!!! I switched the polarity on my driver's side front door woofer and it sounds great! I couldn't believe that trick actually works! Now I have to re-solder the connections on my gf's since her doors have the Crutchfield speaker clips and I'd rather re-wire behind the head unit than take the door apart again. (She has an '01 LX ULEV sedan).
I have MB Quartz front components. The tweeter is a little smaller than the polks. I custom mounted them to the back of the grille. No dash cutting was necessary.
For everyone wondering about what fits well, I just installed my gf's JVC HDR1 head unit, iPod adapter (plug in the slot below the radio with the cover) and a set of Polk slim-fit 5.25's. The speakers fit in the stock brackets, but you have to cut the back of the basket off. I did this with a hacksaw and cleaned it up with a table grinder.
In closing, thanks MacLeod for suggesting to reverse the wiring on 1 front woofer!
Old Sep 17, 2007 | 07:31 PM
  #29
MacLeod's Avatar
Glad it worked for ya.
Old Sep 18, 2007 | 04:49 PM
  #30
falkore24's Avatar
Me too!!![sm=icon_rock.gif]
