The Big 3 upgrade
Falkore I'm not sure how correct that is. Electricity will always take the path of less resistance, so having that small wire still connected isn't going to much if at all. That's why I said you can either replace it or leave it. Also less resistance equals more current right? Or does it just help stabilize the voltage?
Also Arron if you have say 5 8awg wires instead of one 1/0awg, the 8 awgs must all be the same length to function like that or the current wouldn't be even across them all. I'm no electrical engineer but that's how it was explained to me.
Aaron, is wiring kind of like duct sizing? Too big and you won't have enough static pressure, too big of wire and you get a large(r) voltage drop as the length increases?
I too have had benefits from an unequal length eBay grounding kit... but not enough for me to warrant installing it on this car.
Again I'm not sure about this, but I don't think you can have a wire that is too large. Electricity travels over the surface not so much through it. Hence why multi core wire has a much lower resitance than single core wire used in 120v.
Well I was going to do quite a bit to the audio setup like moving the capacitor. But ran into quite a few problems.
1st, no one sells that glow plug thing that allows you to charge your cap so it wont arc. I was told to get a 1.2k resistor but never told about the ohms or watts.
2nd, told to just get a 12v dome light which will do the same thing, bought a bulb and the cheapest socket but it was a stupid round base so it only had one wire.
3rd, I forgot that the fuse holder I have is 8 gauge...ugh
Anyways, I got some copper round spades like you showed me t00fatt and they worked pretty well! All I did was add an extra 4 gauge ground wire from the neg. battery terminal to the bolt that is connected to the headlight. I sanded the paint away for a better connection. Then I put an actual round spade (wire just used to be jammed under the connector on the post)
At first the voltage was jumping all over the place which was unusual, then if I turn on my HID's while driving the voltage drops to 13 and stays there, but if i turn them on right when i start the car it will stay at 14v. Then later, i turned them off and back on while driving and they stayed @ 14v. Sometimes when I stop it drops down to 12v and then goes to 14v if i put it @ neutral.
Need more time to test it out!
