The Big 3 upgrade
Old Mar 29, 2012 | 04:48 AM
  #71
darkgreen18290's Avatar
Will do the ground upgrade hopefully this coming weekend, but I only adding 4 awg wire to bat neg to chassis, block to chassis and chassis transmission, but the wire goes to the bat + to fuse box to alternator will be untouched, is this make any difference to the upgrade at all? Coz I really don’t want to mess this wire and i think its hard to replace.
Old Mar 29, 2012 | 07:41 AM
  #72
keep_hope_alive's Avatar
you can just do the grounds and you will get some benefit. grounds are the weakest part of the OEM wiring.
you don't replace the factory batt + to fuse box to alt. you run a new 4 awg wire from batt + to alt directly, with a fuse at the batt. basically, you introduce a parallel path for current.
Old Apr 1, 2012 | 01:22 AM
  #73
great thanks! will buy another set of wire and a fuse, what amp should i use for this wire (batt + to alt)
Old Apr 1, 2012 | 01:25 AM
  #74
i used a 100A MAXI fuse since my wire was in parallel with the factory wire (current is split between the two wires). but as a general rule - size it for the wire.
zeus159
May 19, 2015 09:05 PM
Pookie
Apr 14, 2013 11:20 AM
HondaAccordEX94
Mar 5, 2010 03:17 PM
mak
Mar 28, 2008 12:29 PM
kramrkixass@yahoo.co
Nov 26, 2005 12:42 PM
