Bluetooth for my 2009 Accord LX
Old Mar 8, 2011 | 10:30 PM
TrinDawg38's Avatar
Default Bluetooth for my 2009 Accord LX
I REALLY want a bluetooth setup for my '09 Accord LX..problem is, I have the stereo WITHOUT the XM button, which I see is needed for pretty much all the bluetooth modules out there. I really don;t want to install an aftermarket stereo because then I'll lose the screen for the radio..SO...does anyone out there know what I can do? Is it possible if I find a stereo with the XM button that I could install this in my vehicle? OR would the wiring be too different? I really would like to hear any options. I really don;t want to use the parrot bluetooth..i was wanting the scosche bluetooth, I think its called bluefusion. I also want A2DP streaming as well...any help would be appreciated.
Old Mar 12, 2011 | 01:23 PM
troycifer's Avatar
why dont you want parrot bluetooth? if you dont like the parrot mki9200 id recommend "the voice" by Got2bWireless. its $90 on sonic electronix. no install just plug into ac outlet or run off battery(rated 230 hours of standby battery). it can be easily moved between cars. and has a2dp.
Old Mar 13, 2011 | 11:08 PM
keep_hope_alive's Avatar
^those solutions use an FM modulator to pass audio to the factory head unit. that's the lowest quality way to do it. you just tune your factory radio to the FM station broadcast by the BT device.
trying to swap radios can be done, but will be a bit expensive. the harness is the same, so that part of the install is easy.
Drachir2000
Dec 3, 2013 12:24 PM
samhurst
Jul 12, 2011 12:51 PM
v_m80
Jun 2, 2008 01:11 AM
Honman07
Oct 24, 2007 03:39 PM
blkdymond
Aug 23, 2007 05:03 PM
