Car Speakers
Old May 7, 2006 | 10:43 PM
tom15425's Avatar
Default Car Speakers
After reading Rick's post about his recent installation, I think I'm pretty set with the Alpine type S's. Would it be strongly recommended to get an amp or will I be okay without it for awhile? I think this is the one you were talking about:
http://www.hookedontronics.com/show_....jsp?cid=19056
Old May 15, 2006 | 10:08 PM
RTexasF's Avatar
Super Member
Default RE: Car Speakers
If you can swing the amp at the same time do it! The upgraded speakers sound much better than the originals but would sound A LOT better with more power. I should have done it when I had the money, now I regret that I did not.
Old May 16, 2006 | 03:41 AM
tom15425's Avatar
I appreciate the reply Texas. I think I'm going to take your advice and go ahead and spend the extra couple hundred on the amp. I may even go ahead and get some dynamat while I'm at it. I guess I just needed the reassurance that the extra money is justified by alot better sound.
Old Jun 12, 2006 | 01:50 PM
04AccordCW
If you have an aftermarket headunit you could run the speakers off that but I would recommend getting an amp if you have the money. Oh and if your running 4 speakers I would strongly recommend an amp the most I would run off the headunit would be 2. My recommendation would be to get cheaper speakers for the back like the Alpine Type S and run those off the headunit then buy some good component speakers Alpine Type R's arent bad and get an amp to power those.
93Accord2.2
Aug 8, 2013 12:46 PM
christian2000accord
Feb 22, 2009 12:33 AM
jonojo
Feb 19, 2009 01:29 PM
botang47
Oct 29, 2008 03:20 PM
parimento1
Mar 23, 2005 03:55 PM
