CD/AUX-ipod adapter installed...intermittent problem
Old Mar 25, 2011 | 11:12 AM
ashbycorner's Avatar
Default CD/AUX-ipod adapter installed...intermittent problem
hey accorders.
So, I finally received an el-cheapo ipod adapter that I bought on ebay. Came as described. With the help of a friend who has a clue, I was able to take out all the stuff I needed to take out (without breaking anything!), insert the 14-pin connectore into the head unit, and voila! iPod. The radio buttons even allowed me to move to the next song!
I was pretty happy!
then, I turned off the radio head unit. The "CDC" option under the CD/AUX went away.
I know it DID work. I've tried several different iPods (all known to be working). All connections were tight.
Any ideas?
Thanks
(It's a 2006 accord, no sat, no nav if that helps!)
Old Mar 25, 2011 | 04:47 PM
keep_hope_alive's Avatar
Bummer. Gonna have to get back in there and inspect the adapter. Disconnect and reconnect. If you have the CODE for the factory radio, try disconnecting the battery to reset the head unit.
Maybe the el cheapo eBay adapters are cheap for a reason. The head unit needs a specific signal to know something is connected.
Does the adapter have dip switches to program?
Old Mar 26, 2011 | 09:32 AM
yup...I unhooked the battery, and got "CDC" back. turned radio on and off, still good. changed ipods, still good.
then I turned the car off.
cdc: gone.
RRRRR.
Old Apr 17, 2011 | 10:00 AM
iluxa1983's Avatar
Hello, I have the same problem.
Do you found any solution?
Old Apr 17, 2011 | 07:30 PM
status's Avatar
i know what your talking about a fellow 7th gen friend of mine has that, if you leave it on cdc you can turn the car off and on no problems, how ever the moment you turn the radio off while power is on it wont recongnize it. i dremmeled a hole in his cubby right where it plugs in so he now can reach in and plug it in and out as needed.
if you want pics i can take some and show you what i mean.
Old Apr 18, 2011 | 11:02 AM
Default bought a "good" unit, reinstalled....
bought a good unit from crutchfield.ca.
reinstalled.
works great! I'm never taking all that stuff apart again though!
Old Apr 18, 2011 | 06:17 PM
It is usually cheaper to buy quality once. Well done.
cowsgonemadd3
May 15, 2010 10:19 PM
nponer
Jan 15, 2009 12:35 PM
slicendice
Mar 21, 2007 08:56 PM
slicendice
Mar 14, 2007 12:33 PM
scifiiman
May 30, 2006 10:23 AM
