Speaker Spacers
Old Apr 17, 2011 | 07:32 PM
swagonpoint's Avatar
Default Speaker Spacers
Has anyone put speaker spacers in the door of a 2000 honda accord sedan? I just wanted to see if 1 inch spacers will fit the speakers without touching the stock speaker grill in the door panel.
Thanks
Old Apr 17, 2011 | 09:35 PM
I don't know but I'll move this to A/V Elect. where you'll probably get better answers.
Old Apr 17, 2011 | 10:38 PM
keep_hope_alive's Avatar
My 2001 doors with a 3/4" MDF and several layers of deadener and foam
Old Apr 17, 2011 | 10:47 PM
1" may be too thick , depends on the woofer top thickness.
Old Apr 18, 2011 | 10:41 AM
Thanks for all the help keep_hope_alive. Im putting in some of these
MM651 Car Audio Speaker from Polk Audio
With crossovers
Do you still think the 1 inch spacers are too big?
If so then where can i get 3/4 inch spacers without cutting my own because i dont have the tools for that.
Thanks again
Old Apr 18, 2011 | 02:35 PM
Where are you getting 1" spacers that are made for an Accord? The issue is that you need to account for foam thickness between spacer and metal and between spacer and speaker basket. I am close to 1" with the additional deadener and foam layers.
I have no idea where you would buy spacers like these. A drill and a jig saw is all that is needed, maybe find someone and buy them a 6-pack?
In a pinch, I have used 3/4" closed cell rubber foam weather-stripping to act as a spacer and seal, then you can use standard 1/2" plastic spacers or adapters. Closed cell is important as it won't compress like open cell foam.
Install is key. Deadening and sealing the doors did WONDERS for mid bass response.
Old Apr 18, 2011 | 06:00 PM
neophyte's Avatar
do you need some 3/4 spacers? i am about to replace my speakers. i am going to have to cut some. i dont have the demensions on a 2000 honda. but if you tell me the measurements i can cut you some out of 3/4 mdf when i cut mine. i would be willing to do the pair for 20 plus shipping. let me know.
Old Apr 18, 2011 | 06:09 PM
I can give you a template, 2000 is the same as a 2001. You will need to know the inside dimension for the cutout. Wood needs to be waterproof, resin is best but deadener can work as shown above.
You can use the factory speaker as a template so the mounting holes are the same. But I prefer bolts in place of the plastic nuts. The plastic nuts just pop out.
I prefer t-nuts for mounting, but you need the drivers for that. The buyer could add t-nuts later.
That is a nice offer and a very fair price.
Old Apr 18, 2011 | 06:26 PM
neophyte's Avatar
i have access to a cnc so it really isnt much work for me. if would come unsanded but if he wants to sand it it would be very minimal sanding. no reshaping needed just smooth the edges a bit.
i also do have resin and dampner at the house. if interested swagonpoint it would change the price but i can do that too.
Old Apr 18, 2011 | 10:27 PM
tkrotchko's Avatar
With crossovers
Thanks again
They make a "skinny" version of these speakers DB651s, which do fit into the front of an Accord using the stock spacers and using the stock "basket" behind the speakers (although you have to use slightly longer screws than stock. They sound okay.
Jan 21, 2008 09:59 AM
Av6coupee
Nov 8, 2007 10:14 AM
crist95
Aug 2, 2007 04:12 PM
rhrhkdals
May 27, 2007 11:42 PM
saad180
Mar 29, 2006 07:58 PM
