Electrical Problems 94 Honda Accord EX
Old Jun 9, 2011 | 09:07 AM
HondaBobo's Avatar
Default Electrical Problems 94 Honda Accord EX
94 Honda Accord. I have some electrical problems... And I don't know what I'm doing, so, have fun:
Problem: Radiator fans won't turn on and there's a black wire going back toward the driver compartment, but is connected to nothing. It's coming off of a green wire on the radiator. I thought maybe there had been a switch there before or something.
Also, my front left headlight works, but is really, really dim, as if it doesn't have enough power. All other lights are bright and fine.
So... I don't know what information to give you, but here's a start... Any suggestions on what to do first?
Old Jun 9, 2011 | 02:31 PM
Spyfunkr's Avatar
Test the radiator fan by jumpering it directly to your battery. If it comes on, fan is good, switch might need to be replaced. You can search the internet for parts that might need to be there
Switch the head light bulbs between left and right. It the left bulb is dim in the right side, problem is bulb. If not, check that there is no corrosion(green crap) around the connector. If there is, clean it with baking soda and water.
Good luck! Spy
Old Jun 14, 2011 | 07:07 PM
keep_hope_alive's Avatar
using a DMM to test the fan connections is safer than connecting it to the battery directly. if the fan is shorted wiring it without a fuse could be dangerous.
the fan requires two connections to work. one from the vehicle controller and one goes to ground.
Yankee30
Apr 24, 2013 06:54 AM
deuce1817
Mar 29, 2013 01:14 PM
HondaNatey
Mar 11, 2011 12:06 PM
chillnndc
Nov 27, 2010 09:05 AM
eze123
Jul 16, 2010 12:29 AM
