Flip up screen in lower cubby - 03 EX
Old Aug 3, 2007 | 10:58 PM
t00fatt's Avatar
Default RE: Flip up screen in lower cubby - 03 EX
Yea it does, but it will turn your dual climate to single climate control, and be careful as you need the kit for dual climate control.
Old Aug 3, 2007 | 11:35 PM
smaglik's Avatar
ORIGINAL: HuYnHness
i think i may have screwed up my factory HU so i might end up having to get that metra kit sometime but does it work on the cars with dual climate control?
what did you do to your head unit?
Old Aug 4, 2007 | 01:30 AM
HuYnHness's Avatar
i really honestly do not know like i said in my other post i was just tapping into the harness for an output converter (with my battery and everything disconnected of course) and now i get no sound from it
Old Aug 4, 2007 | 07:27 AM
smaglik's Avatar
oh...ok...i wasnt sure if it was the same vehicle / member....and i was too lazy to look. that kind of scares me from f'in with mine.
Old Aug 4, 2007 | 11:25 AM
sir_nasty's Avatar
ORIGINAL: HuYnHness
I don't know about honda HU but a lot of decks have a fuse in the back of them, did you check that?
Old Aug 6, 2007 | 02:50 PM
guypatterson
Sorry about the bad links, they were sent to me through our email.
Is "molding one in there" hard to do? I've installed all my decks in the past but used kits. Don't think I'd want to risk trying it myself unless is easier than i think.
I really want to put in a dvd player, but the kit that replaces the entire stock stereo is out of the question - I hate how it looks. I want to keep it and install a screen elsewhere. Any good suggestions that won't cost way too mcuh and won't require much custom work?
Old Aug 6, 2007 | 11:20 PM
  #17
stevent's Avatar
you can try something like this http://www.gcsrts.com/srts-admin/pictures/IMAGE_00293%20(Medium).jpg or something like this like I did but for my 6th gen http://www.bwimports.org/forums/imag...8/IMG_0981.jpg
Old Sep 11, 2007 | 01:26 PM
  #18
guypatterson
I really like the first one. Any tutorials?
Old Sep 11, 2007 | 06:09 PM
  #19
HuYnHness's Avatar
ORIGINAL: sir_nasty
ORIGINAL: HuYnHness
kinda late but if it was a fuse behind the radio it shouldnt short out the fuse under the dash would it?
Old Sep 11, 2007 | 07:07 PM
  #20
stevent's Avatar
ORIGINAL: guypatterson
I did the same thing to my car except my car is a 6th gen but practically the same modification.
Materials:
[ol][*]An audio attachment kit[*]A headrest monitor[*]dremel[*]bondo[*]sand paper[*]paint
[/ol]
1) You need to purchase an audio attachment for your car.
2) Then you need to get a headrest monitor. 7 in is what I have in my car and I dont think you would want to go wider than that. But measure the audio attachment to make sure 7' would fit.
3) After you have those to items, take the monitor and take it part. Make sure you do it carefully since you don't want anything to be ruined.
4) Take the bezel (front part of monitor) and place it in front of the audio attachment kit, also if the screen is not removed, remove it.. Center it.
5) If the bezel and the attachment kit does not fit, then this is where you are going to have to use the dremel to cut the attachment kit to make it fit around the bezel, at the same time making sure it would fit in your cubby.
6) After you have done this modding, get some bondo and fill the area around where bezel and the attachment kit touches. Make sure you do not get
bondo on the edges of the screen housing.
7) After bondo-ing, sand it. Primer, sand, primer; keep doing this process until it's smooth to your liking. Wet sanding is also an option.
8) Then spray paint he bezel.
9) Reassemble everything and your finished.
Here's a thread for picture purposes. http://www.v6performance.net/forums/...t=cubby+screen
The guy in the thread is very handy at doing this.
wrencredle
Jun 27, 2012 08:38 PM
cbraccord
May 3, 2011 10:39 AM
saaketham
Jan 20, 2008 02:48 PM
jschustak
Nov 13, 2006 05:03 AM
id 713
Nov 9, 2006 02:53 AM
