Is the ground wire on the factor harness adequate?
Old Dec 31, 2007 | 10:54 AM
Contriver's Avatar
Default Is the ground wire on the factor harness adequate?
I just got an 03 LX sedan and I am going to put the Kenwood deck from my old vehicle into it. I purchased the "storage box" install kit. Anyway, with previous vehicles I'veowned, I've hadbad experiences when using the ground wire on the factory wiring harness (none of which were Hondas). It always seemed to work better to ground the radio directly to the body. Have you guys had good luck simply using the ground on the factory harness?
Old Dec 31, 2007 | 11:29 AM
sir_nasty's Avatar
Default RE: Is the ground wire on the factor harness adequate?
I've had my stereo in 2 different honda's with the stock ground wire without issue.
Old Dec 31, 2007 | 11:30 AM
benjiaccord's Avatar
I, like you, have a Kenwood deck, have had many actually! Anyways, two different Hondas 4 different kenwood decks, factory ground everytime, no problems ever
Old Dec 31, 2007 | 12:11 PM
Contriver's Avatar
Factory ground it is Thanks guys!
Old Dec 31, 2007 | 12:18 PM
Contriver's Avatar
One more thing, as far as I understand it, the blue wire is onlyfor motor-driven antennas, yet the kit's harness has a blue wire on it. Should I hook it up anyway?
sir_nasty's Avatar
Hook it up since that's what most people use as their power on wire for amps. If you ever want to add an amp you'll want that wire.
Tobey Hall
Feb 4, 2015 05:45 PM
magiconthetire
Oct 29, 2007 12:21 PM
03Sleeper
May 2, 2007 08:01 PM
Green_Accord
Apr 5, 2006 04:11 AM
F23AccordLX
Feb 24, 2006 07:48 AM
