Having a very ODD problem after amp and sub install on 2011 accord.
Old Nov 26, 2011 | 09:29 AM
Tolson0123's Avatar
Hey guys, I am new to this website and this install.
I know it is a fairly old thread but I was wondering, what type of line convertor did you use? Are there distinguishing factors between different line convertors? I have never installed a sub before and am having one shipped out early this week, I am attempting to buy all of the necessary parts before it arrives. It is a package with a sub/amp/wires.
Thanks!
Old Nov 29, 2011 | 06:23 PM
keep_hope_alive's Avatar
Thanks!
yes, there are differences in LOC quality. David Navone Engineering makes the best in the business and they include a remote turn-on output which is needed. PAC-Audio makes plug-and-play interfaces that save you from cutting wires.
Old Apr 12, 2014 | 08:55 PM
James Meadows's Avatar
Default Stereo problems in hondas
I have the fix for my 2014 Honda accord and what I had to do is unplug the noise cancellation box behind the dash and it fixed the loud bass noise you are getting.
Originally Posted by mgg4591
I just installed a 10 inch sub and 1000 watt class d mono kenwood amp in my 2011 accord coupe ex. But i am having a very odd and annoying issue that i hope you guys could help me with.
I used a line out converter because i kept the factory head unit, and just unplugged the connector to the factory sub. For some reason when i give the car gas, whether driving, or just giving it small revs in park, when the rpms drop back down to idle, i get a loud BWWWAHHHHH out of the sub. Like a long deep bass note even if the volume is on 0. Even more odd, the noise goes away if i open a door.
So if i leave a door open and rev the engine, the stereo sounds fine and there is no noise. But if i close the door it and rev it, or go drive, it makes the loud bass note that vibrates the whole car when the rpms drop.
I ran the power wire from the battery + to the amp through the hood latch cable hole in the firewall. I used a 12v ignition power source as the remote wire. I then have the back speakers wired into the amp through a line out converter. For a ground i used a screw on the rear deck that holds down the car seat anchors.
I tried 3 different line out converters, a different amp, and different remote wire source, and a different ground source, but nothing worked. I have no idea what is going on, and if you guys could help me i would greatly appreciate it.
I used this same setup in my old 99 Saturn and had no issues. Used the same line out converter with the factory head unit and had no issues.
DerHaggis
Nov 13, 2012 08:21 AM
StevenVergara
Oct 5, 2012 07:41 AM
jlabbe212
Jun 21, 2011 08:58 PM
wickibet
Nov 10, 2010 12:05 PM
Fat Ryan
Apr 16, 2010 09:50 PM
