High beam Relay location
Hi,
I own a 2005 Accord coupe. I am planning to do some modification to the High beam and low beam wiring. I am more interested in the signal from High and low beam switches. Since my project will require more relays I want to place everything near the existing relay. But I am not able to locate the relays. Where can I find the relay for headlights? I am a newbe so please tell me in details.
Thanks Redbull. I checked the fuse/relay box under the hood but other than fuse, i couldnt find any relays for Headlights. I have attached a pic of the fuse box.
https://answers.yahoo.com/question/i...1115656AA2NNJb
The relay control module is only partially pictured in your photo. (See attached). There are control blocks and various relays (for horn, headlights, taillights) incorporated into the module.
It not a traditional relay that you can pull and replace. The module is built into the fuse/relay box.
Thanks man.
Can I access the Headlight switch and Key II or III from under the dash fuse box? I have seen there is a harness, but not sure if that would serve my purpose. Please help me with a pic or diagram.
