High beam Relay location
Old Sep 11, 2014 | 12:40 AM
accord05thirteen's Avatar
Default High beam Relay location
Hi,
I own a 2005 Accord coupe. I am planning to do some modification to the High beam and low beam wiring. I am more interested in the signal from High and low beam switches. Since my project will require more relays I want to place everything near the existing relay. But I am not able to locate the relays. Where can I find the relay for headlights? I am a newbe so please tell me in details.
Old Sep 11, 2014 | 01:53 PM
Does anybody have a clue?
Old Sep 11, 2014 | 02:08 PM
It's part of the relay control module, which is built into the under-hood fuse/relay box.
Old Sep 11, 2014 | 06:41 PM
Thanks Redbull. I checked the fuse/relay box under the hood but other than fuse, i couldnt find any relays for Headlights. I have attached a pic of the fuse box.
https://answers.yahoo.com/question/i...1115656AA2NNJb
Old Sep 11, 2014 | 07:04 PM
The relay control module is only partially pictured in your photo. (See attached). There are control blocks and various relays (for horn, headlights, taillights) incorporated into the module.
It not a traditional relay that you can pull and replace. The module is built into the fuse/relay box.
Old Sep 11, 2014 | 10:05 PM
Thanks. How can I get access to it? Or If I get access to High and low beam trigger from the switch it would be great. Also, the II of key.
Old Sep 12, 2014 | 11:17 AM
________
Old Sep 12, 2014 | 12:31 PM
Thanks man.
Can I access the Headlight switch and Key II or III from under the dash fuse box? I have seen there is a harness, but not sure if that would serve my purpose. Please help me with a pic or diagram.
Old Sep 12, 2014 | 10:25 PM
Hi Redbull, any idea?
Old Sep 13, 2014 | 12:19 PM
Explain what your project suppose to do.
