horrible reception...
Old Jul 2, 2022 | 04:05 PM
elcamino39's Avatar
Default horrible reception...
i have an 04 accord sedan with the factory amfm radio... the reception is non-existant. is this a common problem? what should i start looking at to remedy this issue?
Old Jul 21, 2022 | 07:53 AM
keep_hope_alive's Avatar
Possible that the antenna connection has come loose or is damaged. Did you buy the car used? If so, it's possible a previous owner was back behind the radio messing with wiring and left it unplugged. Also possible the connection to the antenna came loose. After 18 years, a number of things are possible and inspecting connections is the first step. Those radios are prone to failures, which means it's likely someone was back there at some point.
Chapados
Sep 28, 2018 06:33 PM
Tofu412
Nov 28, 2017 10:41 PM
jz99927
Apr 11, 2014 02:10 AM
accordion5050
Jun 23, 2012 08:34 PM
Patrick111487
Nov 29, 2005 02:43 AM
