How To Program Key Fob for 06 Accord?
Old Mar 28, 2010 | 04:36 PM
toicy4ya's Avatar
Default How To Program Key Fob for 06 Accord?
Sup Everyone,
I cant lock\unlock or open the trunk using the key remote. It stopped working from one day to the next. Initially i thought maybe the battery needs to be replaced but the red light illuminates on the key remote whenever i press a button. I think it just may need to be re-programmed. I thought i saw instructions somewhere on the forum. Anyone know where i might find this information?
Note: I'm not referring to the immobilizer or chip in the key. That works perfectly fine.
Any feedback would be greatly appreciated. btw, i tried search but it didnt yield any positive results.
Thanks
Old Mar 29, 2010 | 07:55 AM
keep_hope_alive's Avatar
replace the battery first, they fail like any other battery and it may be strong enough to light the LED but not enough to reach the car.
Old Mar 30, 2010 | 07:50 AM
toicy4ya's Avatar
I replaced the battery to the key fob yesterday to no avail, im still having the same problem.
Does anyone have the Key Fob programming instructions to lock\unlock the doors and unlock the trunk for an 06 accord?
Old Mar 30, 2010 | 11:51 AM
Try this. But if your doors work OK & it's just the trunk that's a problem, I bet this won't change anything. Do you realize the trunk has a delay of 1 or 2 seconds? You have to hold the button, can't just press it quickly like the doors. That's not a problem, it's a "feature".
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
csh217
Jun 17, 2014 05:53 PM
tradosaurus
Dec 8, 2011 01:29 PM
Moonstone
Jan 2, 2011 01:03 PM
christo16
Oct 4, 2009 10:26 AM
djsmom
Apr 1, 2006 06:10 PM
