AMP questionss
Old Mar 29, 2010 | 10:36 PM
Jay18792's Avatar
Default AMP questionss
Can i connect the speaker wires coming from my AMP to my Speaker well the Speaker is still connected to the head unit wires or how does that go?
Old Mar 30, 2010 | 07:20 AM
I don't quite understand the question, but I think the answer is NO. You shouldn't have speaker leads from the head unit, along with speaker wires from the amp, BOTH going to the same speaker.
I'll move this to the A/V Elect. section where the audio gurus hang out.
Old Mar 30, 2010 | 12:39 PM
keep_hope_alive's Avatar
Jim is right. If you plan on powering a speaker from an amp, you need to disconnect any other speaker wires connected to it, i.e. from the head unit.
each speaker can only be powered by one source - head unit OR amplifier.
if you are trying to get the signal from the head unit to the amp (i.e. high-level inputs to the amp or a LOC) then you can tap the factory speaker wires.
Old Mar 30, 2010 | 02:14 PM
legionofone's Avatar
it needs to go like this Head Unit > RCA Cables out the back of the head unit > RCA cables into the amp > speaker wire from amp connectors to the speaker (make sure you keep the polarity correct)
drumdoctor
Jan 16, 2012 09:53 AM
CarlisleP&SPaddy
South
Jan 22, 2010 10:39 AM
zachyzissou
Feb 15, 2009 11:12 PM
Nadoo
Jan 7, 2008 12:19 AM
