AMP questionss
Old 03-29-2010, 10:36 PM
Jay18792's Avatar
Default AMP questionss
Can i connect the speaker wires coming from my AMP to my Speaker well the Speaker is still connected to the head unit wires or how does that go?
Old 03-30-2010, 07:20 AM
I don't quite understand the question, but I think the answer is NO. You shouldn't have speaker leads from the head unit, along with speaker wires from the amp, BOTH going to the same speaker.
I'll move this to the A/V Elect. section where the audio gurus hang out.
Old 03-30-2010, 12:39 PM
keep_hope_alive's Avatar
Jim is right. If you plan on powering a speaker from an amp, you need to disconnect any other speaker wires connected to it, i.e. from the head unit.
each speaker can only be powered by one source - head unit OR amplifier.
if you are trying to get the signal from the head unit to the amp (i.e. high-level inputs to the amp or a LOC) then you can tap the factory speaker wires.
Old 03-30-2010, 02:14 PM
legionofone's Avatar
it needs to go like this Head Unit > RCA Cables out the back of the head unit > RCA cables into the amp > speaker wire from amp connectors to the speaker (make sure you keep the polarity correct)
drumdoctor
01-16-2012 09:53 AM
CarlisleP&SPaddy
South
01-22-2010 10:39 AM
zachyzissou
02-15-2009 11:12 PM
Nadoo
01-07-2008 12:19 AM
Quick Reply: AMP questionss
