installing alarm - horn wire location
Old Aug 23, 2011 | 01:49 PM
crispin's Avatar
Default installing alarm - horn wire location
Hello,
I am installing an alarm on my 1997 Accord
I cannot find the horn wire under the dash.
It is supposed to be a blue/red or a green/blue in the steering colume harness.
I cannot find it, any tips?
Old Aug 23, 2011 | 06:51 PM
crispin's Avatar
I have decided to order a siren instead of using the horn as I could not find the wire,
Old Aug 24, 2011 | 12:34 PM
keep_hope_alive's Avatar
1997 Honda Accord Car Alarm and Remote Car Starter Wiring Information
Constant 12V+ Wire: White
Constant 12V+ Wire Location: Ignition Switch Harness
Starter Wire: Black/White
Starter Wire Location: Ignition Switch Harness
Ignition Wire: Black/Yellow
Ignition Wire Location: Ignition Switch Harness
Ignition 2 Wire: White/Black
Ignition 2 Wire Location: Ignition Switch Harness
Accessory Wire: Yellow
Accessory Wire Location: Ignition Switch Harness
Tachometer Wire: Green
Tachometer Wire Location: Distributor
Neutral Safety Wire Wire: None
Brake Switch Wire: Green/White
Brake Switch Wire Location: Brake Switch
Trunk Pin Switch Wire: Orange (-)
Trunk Pin Switch Wire Location: Factory Alarm Harness
Trunk Release Switch Wire: White/Red (+)
Trunk Release Switch Wire Location: Driver’s Kick Panel
Parking Lights Wire: Red/Black (+)
Parking Lights Wire Location: Blue Connector at Fuse Panel
Headlight Wire: Blue
Headlight Wire Location: Blue Connector Left of Column
Door Trigger Wire: Black/White (-)
Door Trigger Wire Location: Driver’s Kick Panel
Door Lock Wire: Black/White (-)
Door Lock Wire Location: Alarm Harness in the Driver’s Kick Panel
Door Unlock Wire: Orange (-)
Door Unlock Wire Location: Light Green Connector
Horn Wire: Green/Blue (-)
Horn Wire Location: Gray Connector Left of Column
Old Aug 24, 2011 | 12:36 PM
or you could just connect it at the horn itself. if you add a siren you need to route wiring into the engine bay anyway.
and FYI - i think that a good place for a siren is under the battery tray. not accessible so the wire can be easily cut.
in addition, make sure that the brain is not visible under the dash, and that the brain power is hidden, not at the battery. you don't want someone to bypass the alarm by simply popping the hood and pulling the fuse.
Old Aug 25, 2011 | 01:11 AM
crispin's Avatar
I looked for over an hour for that Green/Blue wire, It cannot be found by me anywhere.
Well let me rephrase that, I did find a Green/Blue wire both under the dash and in the harness passing through the firewall on the drivers side.
However that wire, when grounded out, did not make the horn sound.
I ended up giving up and ordering a 20 watt siren from ebay. I wanted to use the factory horn as I think it is loud and very recognizable vs. the standard alarm siren everyone else has.
Has anyone been successful tying into the factory horn for the alarm?
Thank you for the help anyway.
EnvisionMan
Apr 3, 2012 08:46 PM
AccordLXMaster
Jun 19, 2009 05:25 PM
bill1944
Jan 9, 2009 09:37 AM
tcas1355
Jun 7, 2007 06:35 AM
phaders
Jan 19, 2006 12:03 AM
