installing tweeters
Old Mar 23, 2011 | 10:20 PM
neophyte's Avatar
Default installing tweeters
i am trying to decide where in a 03 accord would be the best place to put tweeters. i was thinking i could put them in the corner between the door and the a pillar. the only problem with that is i dont think that is deep enough so i would have to build up the plastic piece. if that would be a good place what would be a good product to add to plastic to make it look good?
Old Mar 24, 2011 | 12:08 PM
keep_hope_alive's Avatar
Apillar mounting usually provides the best combination of sq with stage height. Those plastic pieces are I'm only referred to as sail panels. They require you run tweeter wires through the door.
You can use fiberglass to mold a professional looking tweeter pod.
I am working on a pillar tweeters for a scion tC.
Old Mar 24, 2011 | 04:27 PM
neophyte's Avatar
the problem with mounting in the pillar is i have air bags there. i 1. dont like messing with air bags. their tempermental nature scares me. and 2. dont want to get hit in the face with a tweeter if i ever do have wreck that deploys those air bags.
this is the reason i was going for the sail panels. i dont mind running wire through the door.
where can i get the fiberglass needed to mold.
Old Mar 18, 2014 | 07:42 PM
jkowtko's Avatar
Almost A Senior Member
I have a 96 4dr, Polk DB6501 components in the front, and have mounted the tweeters on the surface of the door sails with a little angle wedge to point them into the cabin a bit. Looks pretty ugly :|
Since many cars out on the road have tweeter grills built into their door sails, I would like to find a way to fab the existing sails with a tweeter grill, possibly by mating the front half of another car's tweeter grills with the base of the Accord's panel.
Has anyone attempted anything like this? Any ideas on which make/model tweeter grills would mate well to our sail panels?
Thanks. John
Old Mar 18, 2014 | 10:03 PM
neophyte's Avatar
I ended up mounting the pods to the sail pillar and then fiberglassing a mold around them. they are posted in "my journey to a better stereo" thread.
Old Mar 18, 2014 | 11:53 PM
for good-looking sail mounts, you need to fabricate a mount that provides a seamless transition. this can be done with modeling clay and fabric if you want a cost-effective solution that doesn't require fiberglass experience or special tools. PVC caps can act as a tweeter mount as well. get creative. figure out a way to incorporate yours into pods.
i use spheres off the a-pillars for improved imaging and stage height.
pham9006
Nov 12, 2007 10:10 PM
trentsize
Jun 24, 2007 09:31 PM
bssmagik83
Apr 5, 2007 04:39 PM
jombolo
Mar 29, 2007 01:29 AM
jimsmith
Jul 13, 2006 05:43 AM
